1 trailer wheel is locking up. HELP!
ColeM1234
I have a 16ft foot trailer 2 axles with electric brakes on both axles. The left front wheel has been locking up. I used to run my break controller at 10 and everything worked fine but the left front wheel now will always lock up unless I turn the controller all the down to 2 but the other wheels still won't lock up at 10 the left front is the only one. I took it apart everything appeared to be correct and I readjusted all the pads and that stopped it from locking up but it now is still doing it even with checking the adjustment is correct. And the rest of wheels are stopping like they should. The trailer has 800 miles on it and the truck I'm using to pull it with also has 800miles both are brand new. The break controller is the GM integrated controller. Any ideas what the problem maybe? Trailer is loaded evenly I even changed it around and it still does it.
11 REPLIES 11
Hybridhunter
Broken or bent spring at that corner?
frankwp
Brand new & only 800 miles? It has a warranty doesn't it?
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
JIMNLIN
I've had that happen on more than one trailer.
What I found was the brake lining on that wheel was grease soaked.
And on another trailer a shackle (side links) on one end of the trailers suspension equalizer bar had flipped over causing the aft end of the spring to be lifted. Made a huge flat spot.
This happened when I pulled a tandem axle GN flatbed trailer across a ditch.
Chuck_thehammer
power not going evenly to all. connections.
mechanical issue with that brake.
the locking wheel has less weight on it do to suspension issue. or way under pressure of tire. (low air pressure)
ColeM1234
mabynack wrote:
I would pull the drum to see what's going on. I've seen that happen when a spring breaks or when the shoe has been contaminated.
The next step would be to check the voltages going to each side to make sure they're correct. Loose or dirty connections can reduce the current flow to one wheel.
yeah I already pulled the drum and didn't see anything but I haven't check the voltage to each wheel.
mabynack
ColeM1234
K Charles wrote:
Has it been that way the whole 800 miles?
it just started doing it 20 or miles ago
ColeM1234
corvettekent wrote:
Is this a flatbed (car) trailer with no weight on it? Mine will lock up too if it is empty but works fine with a load on it.
fully loaded
ColeM1234
To add it just started doing this and this is with trailer fully loaded
corvettekent
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
K_Charles
