2011 Dodge Ram 2500 anti sway bar
rc135raven
Can someone help me understand why our previous 2002 Dodge Ram CTD had a rear anti sway bar but our "new" 2011 2500 6.7 diesel does not? Thanks for any input.
21 REPLIES 21
AH64ID
john&bet wrote:
AH64ID wrote:
John... I see you are online.
Have a photo for us?
OK,OK,OK, I made a major error and statement. For that I am very sorry. Mine DOES NOT have a rear sway bar. I was so sure it did, but I went and looked the next time I was out by it. I am human. My feelings are not hurt for being called out. Good day to all.
Thank you for coming back and letting us know.
See you in other threads.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
john_bet
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
AH64ID
chryslermastertech wrote:
not for srt 10 truck it is for a 2500. SRT 10 parts are in a sepertate book which i dont have because our dealership doesnot sell srt cars trucks as we aer not a 5star dealer so we cannot sell or repair under warrenty (not that i havent) i have to call our districk tech advisor todo any work on them, ( i do have the training on them thou)
There is precious little info on that part number, in fact this thread is on page 1.
The diagram is not a 2500 frame, so???
We have a guy in this thread claiming to have it, only guy I haver ever seen make that claim in 8 years of heavy use on Dodge forums, seems to be ignoring the request for a photo... That doesn't add a lot of credibility to his claim.
-John
AH64ID
-John
chryslermastert
Mel Scwhentner
Chrysler tech/shop foreman 40 years
A.S.E mastertech certfied 30+year
2012 Jeep wk
1965 Chrysler 300
1951 Desoto s15
1965 Chrysler 300 sport
1951 Desoto S15 custom
2015 Viking FQ
subcamper
Adding a sway bar, either to the front or rear, will change the understeer/oversteer behavior of the vehicle. When you add the rear sway bar, the truck will oversteer more. In other words, the rear will break loose sooner than it did without the sway bar. I'm not sure how the oversteer/understeer behavior is on a stock Dodge pickup, so I can't comment on any beneficial/detrimental effects it will have. I added a rear sway bar on my 1994 Suburban and it did change the handling behavior (at the limits). Even if you say it doesn't matter because you don't drive the truck like a sports car, you may have to make an emergency evasive manuever, in which case "at the limits" may occur.
If you add the sway bar, test out the truck in a large empty parking lot(with no trailer) before and after to see what effects it will have.
Steve
Steve
AH64ID
BAR,Rear Sway 05290355AA part number for rear sway bar for 2004 2500 model year in 2004 model year out 2006
i work as chrysler tech/parts person
5300 Part Inquiry
(00540)CALL VINTAGE PARTS AT 1-877-846-8243 TO ORDER. NO LONGER SUPPLIED BY MOPAR.
but there are dealers that have them in stock
no sway bar for 2011
The part listed appears to be for the SRT-10 trucks, not the 2500's.
If you look at the diagram it shows a forward facing anti-sway bar, with a axle-wrap shock (aka power hop damper) and a under-slung 5 lug axle. The SRT-10 runs this setup, not any 2500.
Coincidentally the SRT-10 trucks ran from 2004-2006.
-John
bguy
AH64ID wrote:
john&bet wrote:
AH64ID wrote:
john&bet wrote:
ScottG wrote:
That went away with the 03 updated body. Dodge said the SB wasn't needed because of the increased length and geometry of the new trucks rear springs.
If that is the case then please explain why my '04.5 has one.
Because it's aftermarket.
There wasn't an OEM anti swaybar in 2004.5.
Very, very wrong. No aftermarket suspension parts on this truck. I have owned it since it had 19 miles on it. I ordered it.
Sorry, it wasn't an OEM option so something is up. You cannot have what wasnot offered. You either don't have a rear anti-sway bar, or it's aftermarket. Either way you are the one who is wrong.
Any pics of your setup? Let's see this suspension.
If you ordered it how did it get 19 miles on it? Did te dealership add it on their own? Check your invoice.
Not trying to be a a$$... It simply wasn't offered on any 3rd gen HD Dodge pickup.
You may as well tell me you have an OEM Allison trans too, the odds are just as good.
In the Mopar world almost anything is possible, even things that aren't on the menu.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
AH64ID
-John
john_bet
wintersun
The stiffer the truck frame the less need their is for an anti-sway bar. These bars originated with ultra light weight sports cars. A side effect is that when one wheel hits a bump the force is transferred to the opposite wheel. With my truck when there is no load in the bed the bed this is a positive attribute as it softens the ride. Zero difference in handling with the Big Wig when there is a 3400 lb. camper in the bed or I am towing a heavy trailer.
chryslermastert
thye list them for 2014 2015 2500
Mel Scwhentner
2012 Jeep wk
1965 Chrysler 300
1951 Desoto s15
2015 Viking FQ
chryslermastert
5300 Part Inquiry
Mel Scwhentner
2012 Jeep wk
1965 Chrysler 300
1951 Desoto s15
2015 Viking FQ
AH64ID
-John
