2012 Suzuki SX4 Flat Tow
GregToni
I need some help. I have a Suzuki SX4 which I would like to flat tow. I am confused over the transmission. I have a shiftable automatic, I can put it in auto or it has a "manual" mode in which I can shift through 6 gears.
It has a "mode" button on the console which I can put it in 2wd or AWD. There is also a "Auto" mode on that switch too.
Looking at the REMCO site, if I choose 2 spd CV transmission it is trailer only, but if I select 6 sp manual it is flat towable. It doesn't list the shiftable automatic. So I am confused as to what I have...
Any help is appreciated.
3 REPLIES 3
Nutinelse2do
2012 Motorhome Dinghy Tow Guide say it is 4 down towable with manual trans. Not auto trans. Sounds like you have auto transmission, so as a safe bet, I would say, not towable 4 down.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
BarneyS
Moved to Dinghy Towing forum from Towing.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
MFL
Nomad II
Nomad II
First off, I am not familiar with your vehicle, but in my opinion, your auto transmission with manual shift mode, is a trailer only. With the 6-speed actual manual transmission, with clutch, and maybe manual transfer case shift lever, the transfer case could be shifted to neutral, allowing towing 4-down.
Jerry
