4 down towing auto tranny
pa_traveler
Looked through archives,but seem to keep seeing manual trannys. Can anyone name a few auto trannys any brand car or small truck,that can be towed 4 down auto tranny,thanks. Wife doesn't want a stick shift. Her outback cant be towed its auto tranny.
20 REPLIES 20
Dutch_12078
CA Traveler wrote:
Old-Biscuit wrote:
Check HERE
Gee what a surprise that Remco recommends cars that need a tranny lube pump! Guess who sells tranny lube pumps???
We like our AWD CRV which has adequate room and easy to tow. We've even driven on on beaches. Since it's not FWD we avoid deep soft sand...
Both Motorhome magazine and FMCA have towing guides.
Here's a better link for Remco's Lookup table. It also shows listings for vehicles that can be towed without a pump, such as the 2014 and older CR-V's.
Dutch
2001 GBM Landau 34' Class A
afrescopXx
This is directly from the 2015 CR-V owner's manual (USA) 12/15/2014 revision:
"Towing Your Vehicle
Your vehicle is not designed to be towed behind a motor home. If your vehicle needs to be towed in an emergency, refer to the emergency towing information"
2015 Honda CR-V CANNOT be towed four down.
lostdog
Jeep Wrangler
Chuck n Terri
2017 Heartland 3875FB
2016 Chevy 3500 Duramax
Rica, the old cat
Max E. Dog, the puppy dog
Kirby, the old dog, passed but not forgotten
CA_Traveler
My 04 CRV AWD is towable 4 down.
2014 Grand Cherokee Overland
Bob
CA_Traveler
dicknellen wrote:
2015 CRV is not tow able due to a transmission change. Dick
Are you sure about that? My tea leaves say it only applies to CRVs sold in Japan.
Regardless always make sure you have written information from the mfg on towing 4 down as in the owners manual and of course BEFORE you buy. Never believe a salesman, etc. including any of us...
Bob
CA_Traveler
Old-Biscuit wrote:
Check HERE
Bob
az99
Since you are a Ford guy already, the Focus works well 4 down.
dicknellen
When I had a 2003 Malibu automatic, I put it in neutral with key in accessory position and it towed great 4 down. There are a lot of automatic Saturnโ€™s that are also tow able 4 down. I now tow a 2013 Honda CRV automatic 4 down. CRV 2wd or awd are both towable 4 down, automatic trans only since I think 2007. 2015 CRV is not tow able due to a transmission change. Dick
mowermech
njtony wrote:
2004-2007 Malibu maxx. remove a fuse. turn key to ass, put into drive.4 down auto.
ass?? drive?? Are you SURE about that?
CM1, USN (RET)
2017 Jayco TT
njtony
pa_traveler
Wife thinks she wants a new car,I want it to be towable 4 down. I would be happy with used ,so may end up new or used. I already got a super hitch ,so I can tow boat,and other times want to pull toad behind truck camper,thanks for suggestions. I would go 7 yrs old or newer I have a 2011 f-350 6.7 dually so I believe there should be no problems towing.Just putting a list together ,so we can go to car lots and look at whats towable. We used to always remove camper,last trip to Erie we rented a car cheap for a couple days. I like idea of when were on road for months having a toad.
dicknellen
pa traveler are you wanting new or used? If used how old will you go? How much weight can you tow? Need more info. Dick
gsander1
Cadillac SRX
George in Birmingham, AL
03 Country Coach Magna
rk911
most any Jeep with an auto tranny can be flat towed that also has a manually selectable neutral position manually selectable neutral position in the 4WD transfer case.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
