4 down towing auto tranny
pa_traveler
Looked through archives,but seem to keep seeing manual trannys. Can anyone name a few auto trannys any brand car or small truck,that can be towed 4 down auto tranny,thanks. Wife doesn't want a stick shift. Her outback cant be towed its auto tranny.
20 REPLIES 20
mowermech
Many (but not all) four wheel drive vehicles with a 2 speed transfer case and a NEUTRAL position in the transfer case.
Many (but not all) automatic transmission vehicles can be towed four down with the addition of a lubrication pump ($1000, give or take a hundred or so). Check the Remco website.
There are three viable methods of taking a vehicle with you:
Four down (limited as noted)
On a dolly (Great for front wheel drive vehicles, NOT for 4X4 or all wheel drives, usually not good for rear wheel drives).
On a trailer (GREAT for ANY vehicle up to the weight/size limits of the trailer, but not very convenient).
CM1, USN (RET)
2017 Jayco TT
Rollnhome
Jeep
2008 Discovery 40X towing a Jeep Grand Cherokee
enblethen
Suzuki Grand Vitara
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
FIRE_UP
To start off with, Honda CRV, in multiple years can be flat towed. They are close to the top in terms of "Top pick" for toads. Jeep Wrangler, also of multiple years, auto or stick, is flat towable, as long as it's the 4WD model and has the transfer case that can be put into neutral. They too are close to the Top pic, for flat towable toads.
But, I'd go through the Dinghy Towing Guides of as many years as you like, depending on amount you'd like to spend, to pick out a number of automatics that can be flat towed. Good luck.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
rv2go
2013 Towing guide
2014 Towing guide
For other years just change the date in the url.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
Old-Biscuit
Check HERE
