โSep-15-2022 07:46 AM
โSep-15-2022 10:10 AM
โSep-15-2022 10:00 AM
Gdetrailer wrote:
Costs campgrounds the same money to keep an open but crippled campground open just for electric hookups. Just because water, sewage and restrooms are closed doesn't mean it is cheaper to run. May even cost more in the winter since it would require additional manpower to plow open, salt, maintain campground roads and campsites.
The chance of a plow vehicle of totaling campground infrastructure goes up drastically.. Heavy snow drifts can obscure water and electric pedestals making it a minefield of things that can get damaged.
Campgrounds must also consider safety on not only their employees but you the "guest". Not every road leading to a campground may be safe to use during off season.
You have something wrong if you run out of battery overnight running a propane furnace plus having a propane fridge.
A 30K BTU RV furnace fan uses 10A at 12V, assuming 50/50 run time (30 minutes on per hr) and 10 hrs (for overnight) and that is 100 Ahr of battery capacity needed..
Two group 27 batteries in parallel (70Ahr each or 140Ahr combined) or one pair of 6V GC2 batteries wired in series for 12V at 210Ahr will easily be plenty of battery.
For the record, I used a single group27 combo marine/starting battery for yrs in a smaller 20Ft TT and never ran out of battery overnight using the furnace (13K BTU with 8A fan draw).
During the day while traveling, your battery will be recharged by your vehicle (the amount of charge may vary some due to differences in RVs and wiring to the battery).
Addition of some solar panels on your RV and/or a small portable gen can easily handle the rest of the charging when needed.
As far as propane, generally should be able to get 4-5 days of running your furnace during extreme cold temps with two 30lb cylinders assuming 24/7 operation.
When traveling out of season, it is best to be well prepared to handle most normal and emergency situations.
Plan, plan, plan.
Plan for enough battery capacity for several days, plan for some solar to fill in, plan with a small gen as a final backup plan.
Do a good job planning and there is zero need for campgrounds between your starting point and your destination.
Depending on open campgrounds out of season is a recipe for disaster.
โSep-15-2022 09:55 AM
โSep-15-2022 09:47 AM
Old Days wrote:
I would install 500 watts of solar and 300 amp hours of battery then you will not need a electric hook up. A DC to DC charger is also nice.
โSep-15-2022 09:32 AM
JimJohnson wrote:CA Traveler wrote:
Many RVs with propane can stop overnight w/o electric in spite of poor RV insulation... Others might just leave the RV in FL or TX.
Propane furnaces offen draw a lot of 12v power for both the ignition system and the fan. I am leery about waking up in the middle of the night to find we have a dead house battery. Plus when on electric the refrigerator will shift from propane to that power source.
โSep-15-2022 09:12 AM
โSep-15-2022 09:03 AM
โSep-15-2022 09:02 AM
โSep-15-2022 08:50 AM
โSep-15-2022 08:19 AM
โSep-15-2022 08:11 AM
