Adjustable water regulator
Not_a_Clue
I have a Valterra adjustable water regulator, while at West Yellowstone the water line froze, not very hard just enough to stop the flow of water for a little while in the morning.
Now the regulator will not go back to zero when unhooked from the water supply. It just stays at 45psi. When I hook it back up it goes to from 45 to 85psi.
Is there a way to reset it back to zero or is it down and needs to be replaced?
Thanks
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
FMCA# F412985
Traveling with Robin(friend)& Buddee(cavalier)
5 REPLIES 5
Not_a_Clue
Thanks for the responses, I will be going down to Home Depot and picking up a new gage.
Linda B.
Our Blog
FMCA# F412985
Oaklevel
Mine did the same thing I went to Lowes Home Improvement store bought a new water gauge for a couple bucks & now it works fine again
Matt_Colie
Linda,
The pressure guage is toast. It is a bourdon tube guage and that means that it used a bent and flattened tube that tries to straighten with increasing pressure. Well, freezing it sure increases the pressure.....
Just buy a new pressure gauge and screw in into the hole.
The regulator is probably just fine if it doesn't leak to the outside.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Bobbo
I agree. The gauge is shot. I took the gauge off of mine and replaced it with a 1/8" MIP brass plug. Once the regulator is set, you shouldn't have to change it again. I DO have a gauge with a garden hose connector so I can check water pressure at the hydrant to see if I need the regulator, and again after the regulator if I feel it is necessary. Any big box hardware store should have that plug, and the "Teflon" tape you need to seal the threads.
Bobbo and Lin
Javi1
Most likely you just need a new gage... not the entire regulator..
2015 Keystone Cougar 333MKS
2015 Ford F-350XL 6.7 CC, DRW, RWD
(Finally enough tow vehicle 14,000 GVWR 6062 payload)
