โFeb-06-2016 11:52 PM
โFeb-09-2016 08:16 PM
mkirsch wrote:Rangerman40 wrote:
I already own it for my current set up.....
Then set it up and use it. You have nothing to lose and everything to gain. It will ride better, and it will handle better.
The new RAM is a 1500 right? Factory receiver is limited to 500lbs of tongue weight before you need a WD hitch. That is a RECEIVER limit, not a truck limit.
If your trailer's tongue is over 500lbs, you need the WD hitch even if your truck has auto-level.
โFeb-09-2016 07:56 AM
โFeb-08-2016 09:30 PM
โFeb-07-2016 08:09 PM
rexlion wrote:
Barney is right on the money. The chains hook to the ball shank, so when the trailer pivots it makes the ball shank pivot in its socket against the friction material. Without the chains, the ball will remain stationary (no pivot) and thus no friction to dampen sway.
If you are sure you don't need WD, don't bother buying the Andersen. You can just use a friction bar.
โFeb-07-2016 07:47 PM
โFeb-07-2016 11:53 AM
โFeb-07-2016 10:56 AM
โFeb-07-2016 04:38 AM
โFeb-07-2016 04:24 AM
โFeb-07-2016 03:25 AM
โFeb-07-2016 03:14 AM
โFeb-07-2016 03:09 AM
