Who doesn't like digesting more scale numbers!? Setting up my new 2021 F-150 HDPP (7850 GVWR, 2536 lbs yellow sticker). TT is a Coleman 262BH, 7600 GVWR, 30' bumper to ball. Hitch is a Reese Dual Cam, 1200 lb bars
First pass, truck only (mostly ready to camp, missing about 200 lbs of people and another 200 lbs of stuff in the bed.
- TV Front axle = 3410 lbs
- TV Rear axle = 2772 lbs
- TV total = 6182
Second pass, TT hitched, no weight dist (bars in bed)
- TV Front axle = 2992
- TV Rear axle = 4290
- TT axles = 6358
- TV total = 7282
Third pass, TT hitched, WD bars attached.
- TV Front axle = 3212
- TV Rear axle = 3828
- TT axles = 6490
- TV total = 7040
Fourth pass, adjusted the hitch head a bit further back in attempt to transfer more weight to the FA:
- TV Front axle = 3388
- TV Rear axle = 3586
- TT axles = 6600
- TV total = 6974
Lastly, checked the TW with my Sherline scale it was around 1000 lbs.
I am happy to get the weight on the TV front axle back to almost what it was without the TT. I think that is success. I drove it to the scales in the "Third pass" config and home int he "Fourth pass" config and both felt good. Also happy that I have roughly 800 lbs to work with on the TV payload.
A few thoughts / questions:
- if I add up the TV/TT numbers for the three full passes, they are 13,640 13530 and 13574 each, that is probably within the errors of the scale I think (?).
- I am pretty sure my tongue weight is roughy 1000 lbs, seeing as I verified with the tongue scale, and the second pass with no bars added 1100 lbs to the TV total. However why does that drop when the bars are attached. The numbers say that weight is transferred back to the TT, is that expected? If I think about the angle of the TT being more level I can see that, vs when it's nosed down with no bars attached.
- I am slightly nosed down overall with the bars attached by 2" end to end on the TT. To the eye it looks level, but I might move up one set of holes on the shank if I get motivated before the next trip, or not.
By the way, the truck is awesome, so much power and so smooth compared to the old 2500HD Silverado gasser!
2021 F-150 HDPP EcoBoost
2016 Coleman 262BH
Reese Dual Cam - 1200lb
