โAug-07-2020 05:30 PM
โJul-25-2021 11:12 AM
โJul-24-2021 09:20 AM
โSep-09-2020 06:27 PM
BenK wrote:
Snip...
Aspirin anyone ?
โSep-09-2020 10:33 AM
โSep-09-2020 09:57 AM
โSep-09-2020 09:35 AM
โSep-09-2020 05:54 AM
MFL wrote:
Jim, not to discredit the tire boys, but the manufacturer of the OP's tires says they are LT tires, which I suspect is true with a max psi of 51 and 2,535 LR. .....
โSep-09-2020 04:46 AM
TurnThePage wrote:CapriRacer wrote:That may be technically accurate, but I know from plenty of experience that airing the tires up closer to their max, yields a significantly safer and more stable ride. My Ram 1500 recommends 41 PSI on both axles, which IS enough for stable and safe towing.MFL wrote:
The door sticker is for best ride, but for towing heavy, you need to air up to get full use of tire load capability. Like mentioned full pressure in rear, and try about 42 in the front. A bit of trial, to know what handles best, after all hooked up and towing.
Jerry
Nope! That's not right.
The inflation pressure on the sticker on the door frame includes the max load (GAWR's) and unless specified otherwise, includes the towing limitations published by the vehicle manufacturer.
โSep-08-2020 06:49 PM
โSep-08-2020 06:13 PM
They are XL (extra load) tires, not LT
โSep-08-2020 02:20 PM
โSep-08-2020 02:19 PM
โSep-08-2020 02:07 PM
โSep-08-2020 01:56 PM
JIMNLIN wrote:
CapriRacer and Tireman9 have both told us (for those that don't know them, both are tire engineers) for years a P metric tires max load capacity comes at 35 psi...even tho they may have a 44-51 max psi on the sidewall.
Higher pressures above 35 psi just stiffens the tires sidewall...but doesn't gain any more capacity.
And both engineers have also told us the OPs 275/55-20" tires has a 113T load rating/2535 lb capacity = a P tire.
