Any benefits to high octane
tbolt2000
Are there any benefit to running octane gas when towing? I had heard when towing use high octane gas.
I've done so much with so little for so long, I'm now qualified to do anything with nothing.
40 REPLIES 40
Lynnmor
Winged One wrote:
Those days are gone.
I had a 70 Plymouth (liked high octane) that I decided to try a little mid grade in, just to see. Dear lord, you would think I put a bucket of screws down the carb's throat, for the fit it was throwing. Racing gas raised the octane enough not to kill the car.
You will know if you are running too little octane.
No, you probably won't know if the octane is too low. Horsepower, fuel mileage and engine life will suffer but you won't know without careful checking.
Winged_One
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
fla-gypsy
Not unless the maker requires it in which case you bought the wrong truck IMO.
Lynnmor
drsteve wrote:
No. Computer controlled engines adjust their spark timing to eliminate preignition under heavy load.
That's true, but it can't adjust the compression ratio. Knocking can be caused by other factors besides spark timing. Ford recommends premium fuel for the little Eco-Boost engine due to the very high cylinder pressures.
Mark_Kovalsky
You don't need higher octane in high altitude. The mean effective pressure in the cylinder is lower due to the lower density air, so you actually can use lower octane fuel. That's why the octane ratings at the gas stations at high altitude are lower than at sea level.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
icanon
I use what the manufacture suggests. Only time I use a higher octane is when I know I'm driving in high altitude.
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
drsteve
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
camp-n-family
My manual "suggests" higher octane when towing. I've tried both and haven't found the extra expense was worth it. No real noticeable difference in power or mpg.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
2oldman
no
Sam_Spade
downtheroad wrote:
Use what the manufacturer calls for in the manual.
This. If you are on the ragged edge of needing higher octane gas your engine will TELL you so with a pinging or knocking sound under load. There is NO other reason to pay for octane that you don't need.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
