Aqua Magic IV Issue
Peakstar
So there has been a horrible smell in my bathroom. The seal on the bottom is good, holds water. Then I realized the obvious problem---underneath the water spray valve there is a manufactured hole that leads directly to the black tank! Why is this here? Am I missing something that is supposed to close this hole? I've been having flies come directly into my coach from the black tank through this hole! What the hell??
4 REPLIES 4
Rvpapa
Since that Thetford link doesn't show the part. on the list it is #6. There should be an 'S' shaped piece of hose connected to make a water trap. It is actually an overflow for the bowl. Every time you flush, a small bit of water should enter to keep the trap full.
Art
tenbear
Until you get the problem solved a little duct tape will do wonders.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Ka_Ron
You could try this site. It is for manuals for the toilet you have.
It should show you a parts list
Aqua Magic IV
GENECOP
Something is def missing from that hole....
