Back Flushing the Black Tank
chris3403
Last time when I hooked up the hose to the inlet I got a back splash on the outside so not having time to deal with the issue I disconnected until the next time. So now it's the next time and I hooked the water hose up and the water only goes in about 12 inches and stops. I can see where the water stops. Like there is a vacuum or something that the water can't push through.
Anyone have any ideals?
Also we have an odor problem coming from the black tank.
Thanks
I've been to all 50 States but my RV hasn't.
9 REPLIES 9
ChuckSteed
Iโ€™d buy one of the clear add on flush adapters with gate valve and back flush my tank that way... you can also back flush the grey tanks... Iโ€™ve been using one of these adapters in three different RVs for many years...
You can see whatโ€™s com8ng out of those tanks, the gate valve keeps you from getting unpleasant mess when opening dump cap ,
Iโ€™ve never used the built in back flush on current fifth wheel and donโ€™t intend to.. I donโ€™t want a flooded bathroom due to an unexpected anti siphon valve fail
mudhound
vent pipe
:C
God Bless
harley4275
Mine had a kink in the hose between the aerator under the sink and the black tank. same symptoms you experience.fixed kink and works...make sure the 2 fittings at the aerator are tight also.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
chris3403
Old-Biscuit wrote:
Look inside bathroom sink cabinet.....
Black Tank Flush System has a anti-siphon vacuum breaker device
It is either installed backwards or the nozzle installed in the sidewall of black tank is plugged
OK I see what you are talking about and will remove it later today and check it out to see if it is stuck they couldn't have installed it backwards because it has worked correctly for 5 years.
chris3403
eHoefler wrote:
Do you have the drain valve open to the tank?
I have tried it both ways.
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
ScottG
I had the same thing happen on just one occasion; hooked up a hose to the black tank flush at a CW and it just wanted to blow back at me. So i just skipped flushing that time.
I don't know what caused it but it never happened again.
Old-Biscuit
westend
Lack of venting. Check your tank vent.
'03 F-250 4x4 CC
