Bad Back
Too_Tall
I have four herniated disc and stenosis in my lower back. Have been able to control the pain with drugs. It is getting so I don't sleep past 3 or 4 AM. My DR wants to inject me with steroids. I hear a lot of bad about the shots. I would like to hear from regular folks that are dealing with this problem. I'm 61 and if getting up at 4 is what I have to deal with, well I will.
7 REPLIES 7
Magnum164
I had my first neck surgery 12 years ago and was still in pain until severe pain forced a second neck surgery. For almost those 12 years I have been getting steroid injections. They do help. But at some point they can stop being beneficial. However there are several pros and cons I can think of.
Cons:
Steroid shots helped me, but over time will lower you immune system. Need to consider age as I am 50. I had to get a pneumonia shot, normally given to people 60+ to build their immune system.
Steroid shots will play havok with blood sugar. If you have diabetes, recovering from the impact of the shots can be rough. Always get them in the morning to avoid spikes.
They only last 3 months and can only be given on one side at a time. For me I also have back issues, so I had to very every 3 months depending on which area was hurting the most.
Pros:
The pain is rough after the shots. But will provide relief. Take advantage of the relief to stretch/exercise without over doing it. The more you can move while you feel good, the more benefit you will have from the shots.
It can be very useful as a diagnosis tool, to determine which area of you disks is giving you the most pain. If you do need further treatment, the shots will have already identified the areas of concern.
For me after 12 years the shots no longer worked or lasted more than a few weeks. After running out of options, the Nurse Practitioner recommended it was time for me to consider Radio Frequency Abilation (RFA). If you have not heard of the procedure look it up. After diagnosing which nerves are causing the pain (reason for steriod shots before hand) they "burn" the nerve ends at that disc. That kills the pain signal to the brain. While you still have disc issues, you no longer receive a signal for pain.
I can tell you, they did the left side of my neck a few weeks ago. And I can tell you after the pain of the procedure went away, it has reduced my severe pain by 80%. Yep, that is 80%. I feel very little pain and have full movement in my neck. IN the next two weeks they will do the right 3 disc levels of where my surgery was. I can't wait, and eagerly await the minimal pain from the procedure ๐Ÿ™‚
The procedure is not for everyone, and as you can imagine since I am not feeling any pain, I will not know when I am hurting. So caution is the word. No roller coaster rides!
The nerves do grow back. Takes about 6 months, and after a couple of times many people report they do not need the next procedure for years.
And of course, I have also read the procedure does not help everyone.
Hope my rambling has helped. But definitely ask your doctor about RFA, I may be a strong advocate now:)
johnrbd
I've been dealing for bad back since I was 16. Mostly chiropractor (seems to work well doe me). I only have 3 herniated discs. Mainly I dealt with the pin with ibuprofen.
Now I'm 68, and in May I was diagnosed with late advanced stage of cirrhosis of the liver. Main culprit as best as we can figure, I was probably combination of the ibuprofen and condroitin/glaucosamine.
Be very careful about long term drug use. Get on ultrasound and/or CT on mid-section to check liver condition, before deciding course of action.
Roy_Lynne
There is nothing worse that back pain as it is so hard to treat. My daughter also has herniated disc. She was told by her Physical Therapist that surgery only works about a 3d of the time so she decided not to go that route. Instead she went to a Pain Management doctor who specialized only in treating pain, and she is doing much better. Massage, walking, yoga also helped her a great deal.
midnightsadie
I,ve had the injections for yrs now ,works great . it does take about a week for you to notice,,, hey my back feels great. my ortho doc says surgery is the very last thing to do. your almost out when they do it ,no pain and alot to gain. I.m 67.
amandasgramma
I had the shots and they worked beautifully....for a while. Eventually, (I don't have the bulging disk issue, mind you), the doctor went in and lasered 8 nerves....I'm 95% improved. Be sure to find a good pain specialist....not a GP.....
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
GENECOP
Try the injection, while they don't help everyone it is worth the try.....Back Surgery should be a last resort.......
TucsonJim
My wife tried the injections, and they didn't help her. In fact, the injections seemed to increase pressure and discomfort. She eventually went to Laser Spine Institute for surgery a couple of years ago and achieved 100% relief.
I currently have a very close friend with similar back problems to you. He underwent the injections and they made a remarkable difference in his case. His pain went from a level 6-7 to a 1-2 and it lasted for several months.
I guess each case can be different. If it works for you, great. If not, at least it won't make it worse.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
