โOct-22-2017 08:28 AM
โOct-23-2017 06:30 PM
Durb wrote:
Wow. When I used to do torque wrench training (I did a lot) I would use a torque stick to demonstrate the effect of wind up with extensions and accuracy. I would use a digital torque wrench on the input side of a torque stick that was attached to a transducer and digital meter. The torque stick would indeed wind up and limit the output and there was no impact wrench in the room. This was all documented by the peak hold functions of the equipment.
One of the first rules of good torque wrench technique is to secure your work. Chock your tires when tightening lug nuts and support your receiver if using it to tighten your hitch ball. Simple physics.
โOct-23-2017 01:33 PM
Lynnmor wrote:Durb wrote:Lynnmor wrote:Durb wrote:
Many people torque the hitch ball by placing the ball mount into the truck receiver and applying downward force. When they do this the rear of the truck will squat. The energy used to squat the truck will be deducted from the the torque wrench's output thereby applying less torque to the hitch ball. This number is significant.
This is not correct. When the proper torque reading is met, everything will stop moving and the nut will be properly tightened.
Dream on, I guess you feel the energy used to compress the truck's springs is coming from thin air. Same concept as when using a torque stick; a lot of torque on the input side, the stick serves as a torsion spring requiring energy to twist, limited amount of torque on the output side. With your theory the input torque would always equal the output torque negating the use torque stick altogether. Compression truck spring - torsion torque stick, same concept.
Wrong, a torque stick will only work with an impact wrench, it has no ability to limit the torque of a conventional torque wrench.
โOct-23-2017 01:20 PM
Durb wrote:Uh, torque is force, not energy. But quite simply, you're wrong. Whether a torque indicating wrench is used, or someone puts a known weight at a known distance from the fastener being tightened, the torque will be correct, whether the truck is on springs or blocks.
โOct-23-2017 11:05 AM
โOct-23-2017 10:51 AM
time2roll wrote:
WHEN INSTALLING REESE HITCH BALLS:
torque all ยพ" shank balls to 160 ft. lbs., all 1" to 250 ft. lbs., and 1ยผ" shank balls to 450 ft. lbs.
(all are virtually the same)
โOct-23-2017 10:29 AM
โOct-23-2017 09:45 AM
proxim2020 wrote:
snip....
I normally place a wrench on the nut and slide5ft pipe
over that. I then place another wrench on the ball's wrench flats and either have someone hold that one or block it to prevent the ball from turning. After that just pull tight. It's not hard to reach the high torque requirement when you take advantage of long levers. I've never had a ball loosen on me using this method.
โOct-23-2017 08:56 AM
โOct-23-2017 08:34 AM
โOct-23-2017 07:06 AM
โOct-23-2017 06:41 AM
old guy wrote:
tighten to 450 lbs torque at least, get a new lock washer.
32vld wrote:
Well the truck just had to have the head R&R so the truck had to be towed a few times. This time I bought a new draw bar and 2" ball to get the tow bar level when towing his old truck.
snip...
I did not have a 1.5 wrench so I went to my neighbors house, retired mechanic.
โOct-23-2017 06:22 AM
โOct-23-2017 05:23 AM
โOct-22-2017 10:42 PM
โOct-22-2017 09:23 PM
