โDec-29-2016 01:48 PM
โJan-04-2017 08:19 AM
bob_nestor wrote:I used the knob style from HF and had the same problem. After cleaning the corrosion twice because my engine had no power to start I realized that the knob was unscrewing slightly due to road vibrations and was arcing and contributing to the corrosive buildup.the2sharps wrote:
I tow a 2015 Ford Focus four down. The last step to prepare the car to tow is to disconnect the negative cable from the battery. I mounted a knob style switch under the hood for the disconnect.
I used a knob style switch that came with my Cool Tech wire harness but discovered that it would corrode and fail to make a good connection with the battery. Replaced it with a sealed switch that I got at AutoZone and haven't had problems since.
โDec-30-2016 09:31 PM
โDec-30-2016 10:20 AM
โDec-30-2016 09:55 AM
โDec-30-2016 07:08 AM
โDec-30-2016 04:35 AM
Bud
USAF Retired
Pace Arrow
โDec-30-2016 01:29 AM
enblethen wrote:Will be dingy towing and will be needing to leave the key in the accessory mode.
What kind of toad?
โDec-29-2016 07:33 PM
Bud
USAF Retired
Pace Arrow
โDec-29-2016 06:29 PM
TyroneandGladys wrote:To clarify will be used on my toad.
I see that there are two types of battery disconnect switches a knife blade type and a knob style. Would appreciate your comments about your experience with either one.
โDec-29-2016 03:45 PM
โDec-29-2016 03:15 PM
โDec-29-2016 02:39 PM
โDec-29-2016 02:14 PM
โDec-29-2016 02:04 PM
Bud
USAF Retired
Pace Arrow
