Big Blunder, any suggestions?
dspencer
Not sure if this is in the correct spot and if not just let me know. The DW made a blunder and I wanted to know if anyone else has done this and is there any suggestions as to what to do if anything. Not thinking she laid a hot skillet lid in the sink (which is plastic of course) and it melted a place in the sink. Now it didn't go all the way through but it concerns me. What if anything should I do to repair this or is it repairable? Any suggestions would be appreciated.
20 REPLIES 20
Padlin
If there are no leaks and the water still works then leave it till you get sick of looking at it.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
RoyF
I go with new sink. Besides the appearance issue, you will never be able to thoroughly clean the damaged area.
dspencer
It still holds water fine, is this something that is a have to when it comes to replacing or as long as it holds water am I alright?
restlesswind
I would guess that you will need to replace the sink.It's not usually a major job.
If she can live with the damaged sink,and there is plenty of material left,there probably is not a great rush to repair/replace it.
However,the sooner you can make it pretty again,the more points you will gain!
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
RoyB
This might be a good time to go for a bigger sink if you got room. I made mine alot bigger in my off-road popup without too much effort...
Real easy to install...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
nomad297
Just put a new sink in. They're cheap and easy to replace.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
