Black Water Valve Will Not Close
pmlevine
It was our last TT trip of the season - all was well, I had opened and closed the black water valve at our campsite a couple of times with no issues. The last day after emptying the black water tank I went to close the valve and it wouldn’t budge. When I applied some force the valve rod bent. I straightened it as best I could and tried to close the valve but the metal rod will not move. Now the rod interface at the frame is loose - the threaded hollow screw at the frame that the rod goes through, the and the nut that secures it to the frame are loose, and I don’t seem to be able to tighten it up. Any ideas guys - help ..:
12 REPLIES 12
pmlevine
Thanks everyone for your suggestions. I just installed a temporary (?) valve per member feedback (WNJJ thanks) :
https://www.amazon.com/Valterra-T58-Twist-On-Waste-Valve/dp/B000BGHYJS/ref=sr_1_3?keywords=twist+on+rv+dump+valve&qid=1636654797&sr=8-3
So far so good. Is this add-on valve “street legal”, or will I have repair or replace the original black water valve ?
naturist
About 5 years after buying our TT, I found myself unable to close the black tank valve. Fortunately, it is only a foot or so up a straight pipe from the coupling, so after flushing the tank as thoroughly as I could, I put a cable grabber up there to see if I could get any debris out. Turns out that when they built the trailer and cut the hole in the tank for the drain, they just left the cut out IN the tank. I was able to grab it and drag it out, and the valve closed normally. You may find a similar "objet de art" stuck in your valve.
Cummins12V98
wnjj wrote:
Put one of these on and get through the winter: https://www.amazon.com/Valterra-T58-Twist-On-Waste-Valve/dp/B000BGHYJS/ref=sr_1_3?keywords=twist+on+...
I used one of those to temporarily fix my stuck open POS black tank flex cable valve. Once I returned to my home base I dumped the cable valve and use the guts of the temp valve to fix the POS valve and make it a manual valve.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rockylarson
X2
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
ssthrd
Suggest putting a good flow of water in the tank with a garden hose or a bucket and work the valve at the same time. Could be something stuck in the valve that might free itself with a little help..
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
wnjj
navigator2346
Better stuck open than closed. Replace the valve and be done with it. Consider yourself lucky and go buy a lottery ticket.
Gjac
I drilled a small hole in the top of the valve and put a self tapping grease fitting in there. When every it gets hard to open I pump some grease in there and it operates smoothly again. For some reason it is always the black valve that sticks never the gray valve. You can also just drill a hole and spray lubricant in the hole and put a screw in the hole after the valve is freed up.
pmlevine
Okay guys thanks. We used our TT as a lifeboat when we lost power recently. If we need to find warm shelter this winter, I’ll just put double garbage bags to line the TT toilet, and we’ll hunker down. Black valve R&R will have to wait til later.
Dave_in_TN
Cummins12V98 wrote:
Remove four bolts and replace valve.
X3.
The good news is the tank is empty and you have all winter to fix it.
Dave & Christy / 5 Awesome Girls (28,26,24, 18 and 16)
2021 Grand Design Solitude 378MBS
2019 Ford F-350 SRW 6.7
larry_cad
X2
Today is my personal best for most consecutive days alive.
Our Travel Blog
Cummins12V98
