โJul-06-2020 09:31 AM
โJul-06-2020 04:54 PM
โJul-06-2020 04:31 PM
JRscooby wrote:Desert Captain wrote:
Don't forget a pair of jack stands {or at least one} unless you are willing to bet your life and limbs on your jack and the surface it sits on.
:C
Over the years I have changed a lot of tires, on many vehicles. Other using some jacks with some vehicles, I have never had to get under to change a tire. And doing a lot of other work, I have set many vehicles on stands. Could never do that without at least reaching under the vehicle. IMHO, for a tire change, a stand increases not reduces the danger.
โJul-06-2020 03:57 PM
azdryheat wrote:
A tire blowout on my trailer is something I don't worry about because I run truck tires and not those cheap ST tires. I can use my trailer's jacks to raise the tire off the ground or a 16 ton bottle jack I carry. I don't worry about a lug wrench as I use a battery operated hammer wrench that removes lug nuts with ease. The only tire issue I've ever had was a blowout on my truck due to a failed valve stem. Other than that, my trailer tires have been trouble free.
โJul-06-2020 03:43 PM
โJul-06-2020 02:02 PM
:C
โJul-06-2020 12:50 PM
kellem wrote:
Reminds me of close friend who is the epitome of preparation.
He has onboard air compressor, air tools, patch kits, you name it he has it.
I always feel more confident towing with this guy.
โJul-06-2020 12:39 PM
โJul-06-2020 12:05 PM
Desert Captain wrote:Sjm9911 wrote:
Good advice. I always put full pressure in my tires btw, never had them explode or run hot on my TT. Only other thing to add is make sure if you need a jack , its the proper size, and leveles can be a lifesaver, not all flats are on level ground! Stay safe.
:C
โJul-06-2020 12:03 PM
BenK wrote:
Good write-up and ask if you do a lot of slow maneuvering on pavement ? and some noodling for thought over the never ending ST tire debates
How level is your setup ? Meaning does both or all axles share evenly...or nose down will have the front axle take more...and if nose high, the rear axle will take more
Have always thought that low speed maneuvering, on pavement contorts the tire carcass and the plys of both tread & sidewall, over time, begins to separate and/or are weakened where the cords lose rubber adhesion
Also wonder if single axle trailer have similar number or percentages of ST tire blow outs. As when they maneuver on pavement, the tires do NOT contort. They just pivot like the TV's steer tires would with power steering
โJul-06-2020 11:50 AM
โJul-06-2020 11:33 AM
โJul-06-2020 11:19 AM
โJul-06-2020 11:15 AM
โJul-06-2020 09:41 AM
