โNov-14-2015 11:26 AM
โApr-15-2016 05:29 PM
RVcircus wrote:
what if you make a shim using the inside of the window trim and or the window opening as a template? I'm thinking butyl tape will be a better deal long term than just ProFlex assuming you can compress it.
โNov-14-2015 05:48 PM
โNov-14-2015 05:28 PM
beemerphile1 wrote:
You used butyl tape or putty tape? There is a big difference in both price and performance.
RVcircus wrote:
(I give it a day or so before trimming) and then seal with a bead of ProFlex to be safe.
โNov-14-2015 04:33 PM
โNov-14-2015 04:01 PM
โNov-14-2015 12:23 PM
Chris Bryant wrote:
You should not have to double up the butyl on a smooth skin, so I would say the you need to shim the trim ring inside to make it shug.
โNov-14-2015 11:40 AM
โNov-14-2015 11:33 AM
โNov-14-2015 11:32 AM
