Here is a what I found from a manual online, you should consult your owners manual for your specific truck though to be sure. But based on what you said since it's a 4x2 not a 4x4 the answer is no.
Chevrolet Silverado Owner Manual - 2011
Dinghy Towing
Two-Wheel-Drive Vehicles
Notice:
If the vehicle is towed with all four wheels on the ground, the drivetrain components could be damaged. The repairs would not be covered by the vehicle warranty. Do not tow the vehicle with all four wheels on the ground.
Two-wheel-drive vehicles should not be towed with all four wheels on the ground. Two-wheel-drive transmissions have no provisions for internal lubrication while being towed.
Four-Wheel-Drive Vehicles
Use the following procedure to dinghy tow a four-wheel-drive vehicle:
1. Position the vehicle being towed behind the tow vehicle and shift
the transmission to P (Park).
2. Turn the engine off and firmly set the parking brake.
3. Securely attach the vehicle being towed to the tow vehicle.
4. Shift the transfer case to N (Neutral). See โShifting into Neutralโ
under Four-Wheel Drive on page 9 for the proper procedure to select the Neutral
position for the vehicle.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
