โMar-29-2014 11:53 PM
โApr-02-2014 12:14 PM
Golden_HVAC wrote:
Yes it is time to upgrade those speakers. Most manufactures do not spend a lot on the radio in RV's as it is not a big selling point. Something more flashy, such as flat screen TV will sell more RV's.
Fred.
โApr-01-2014 07:28 PM
โApr-01-2014 06:49 PM
โApr-01-2014 06:13 PM
โApr-01-2014 04:59 PM
โApr-01-2014 02:11 PM
BobsYourUncle wrote:
Gee the stereos they put in the RV's are sure P poor!
And the speakers! Makes my music sound like 2 tin cans on a string.....
OK, I come from a background of loving music. I was a DJ in a radio station in Alberta at the tender age of 15. I love my music. Alway have, always will.
Over the years I have always loved music. I have my own tastes and favorite artists from years gone by.
Once in a while ๐ a song comes on the radio and I get this urge to wind it up a bit. I'm alone here, nobody within earshot anywhere. So when I hear a song and want to dial it, I do!!
But then the awful cheapo stereo sets in. The rattly speakers, the droning vibration - ugh! Sounds awful! Reminds me of the cheap 8 track I had in my first car!
Suppose I could buy something better and upgrade the speakers to something that doesn't sound like a kiddies tunebox.....
My home stereo could make your ears bleed, with no distortion! haha!
โApr-01-2014 12:42 AM
โMar-31-2014 10:04 PM
Carb Cleaner wrote:
It's not about quantity, it's about quality.
From what I remember, a clean, higher-wattage amp will give you better sound at lower volumes, too. I'm not saying 1,800 watts to a 15" woofer. I'm thinking maybe 100 watts to an efficient 8" driver. I don't have to rattle the neighbors' windows, but when I'm watching The Wizard of Oz, a little bass during the Great and Powerful Oz scene would be cool.
That's a Pink Floyd reference, if you didn't catch it.
โMar-31-2014 08:23 PM
ericsmith32 wrote:
Along the same lines.. For those with Class A/C's what type of systems do you have? Was thinking about buying 2 Pioneer headunits one for the front and another for the back. Almost seems like a waste but it's the only way I can see it working. One would have 2 6x9's tied to it for the TV etc. Don't have a big enough inverter to run a regular stereo.
โMar-31-2014 04:50 PM
ericsmith32 wrote:Yes, a 12V headunit will be more efficient electronically. Even the best 12V HU only pushes 20 W. A lot of it depends on how Pink you want your Floyd.:Bwestend wrote:ericsmith32 wrote:Your inverter is less than 100 W? Typical modern stereo receivers are approximately 40 W draw at 120V AC. My LCD TV draws 33 W at typical settings and volume.
I think it's 200w/400w max but it's a cheapy HF model. It probably would but the receivers I have are a bit big. A regular headunit would be smaller more efficient was my thought.
โMar-31-2014 04:14 PM
โMar-31-2014 04:08 PM
tpi wrote:
ericsmith.. sounds good to me. Personally I just use the head unit amp to keep power draw down. 6X9 are about as efficient as possible w/ typical car audio and are large enough to have pretty decent lower bass response. You could possible tie the two head units together into each other's aux input so once source could drive all the speakers.
Westend touched on it too.. be sure to check head unit or amp output impedance rating and match speaker to it. If it is 4 ohms, use 4 ohm speaker. If it is 2 ohms try to find 2 ohm speaker or run two fours in parallel. Bottom line is you want draw as much power out of the amp as possible, especially in marginal situations where loud sound is desirable.
โMar-31-2014 02:59 PM
