โMay-06-2014 11:49 AM
โMay-14-2014 06:06 AM
mhsmith wrote:
I agree with Gdetrailer as far as the pads most likely being stuck. At some point(you added the trailer) and the brake problem became coincidence. The pads were "stuck" and unable to release properly and wore down to where they are not a problem right now. Most likely the pads and pad hardware need to be removed, mounts cleaned of rust and I also like to put a dab of silicone under the hardware to slow down the rust build up.
โMay-11-2014 07:56 PM
โMay-11-2014 06:03 PM
Gdetrailer wrote:
You have been leading a charmed life to find "dealers" which can actually "fix" something.......
...snip.....
โMay-11-2014 05:23 PM
gmw photos wrote:BenK wrote:
Boils down to who the OP believes...or trusts over all of the advice so far
Agree that it 'can' be a mechanical issue with the caliper...as it could also
be an electronic issue with all of the tuff tied together inside the computer system(s)
So much of the advice is based on historically empirical data, but ask if that
includes computer systems and process controls? Even an understanding
of real time and master slave hierarchy...
That is what 'might' be the cause inside of these 'highly integrated' computer
systems
To diagnose these computer systems will require the over all knowledge, a logic
diagram (down to a level of detail to show internal logic for each module, etc)
and a GREAT scan tool (no longer the $500 buck range, but thousands to tens
of thousands of bucks range)
Stuff like with the multiplexed data stream(s) the Master CPU (yeah, gotta understand
master slave on real time metrics here) is not corrupted somehow. Can even be
noise on the power supply or once of the sensory feedback lines, to
a now higher resistance line that messes up the logic timing...and a BIG ETC
So to the OP...do you trust that your mechanic did a good diagnosis and found
nothing wrong with the mechanical brake system? If still worried about that, then
the cheapest at this point is to have 'that' wheel's brake caliper and hose
changed
Or just leave it as is and hope for the best...
Very true, Ben. Which is why I posted up above several posts that for stuff like this in the modern world, I have come to have more confidence that a good OE dealer has a better shot at troubleshooting and fixing this stuff.
Our Ford goes to the Ford shop. The Nissan goes to the Nissan shop. In our case, both of these dealers have been able to fix whatever issue the trucks went in for.
โMay-11-2014 04:22 PM
systems
changed
โMay-11-2014 11:30 AM
โMay-11-2014 01:41 AM
โMay-10-2014 12:28 PM
โMay-10-2014 10:32 AM
life_is_an_open_road wrote:
Thanks to all those who provided input on this one-time (hopefully!) braking issue.
I just got the truck back from the shop where a full four wheel brake inspection was performed. The technician found that the front driver side rotor was discolored so it had indeed seen some excessive heat. That being said, it wasnโt warped, the calipers werenโt sticking or grooved and there was no rust present. The pads are 40% worn so with over half their life left it didnโt seem appropriate to change them. (The mechanic concurred.) They witnessed nothing wrong with the hydraulic lines or any of the hoses. The brakes on the other wheels were similarly given a clean bill of health. The tech took the truck for a spin and did several hard applications of the brakes. He couldnโt get the brakes to lock up and the shopโs thermal probe indicated no out of the ordinary rotor temperatures โ of course all this testing is being done without the truck being hitched to my trailer.
โMay-10-2014 07:23 AM
โMay-07-2014 07:05 AM
Gdetrailer wrote:
Front drivers side rotor too hot to touch.. THAT is the problem..
You have one of several possible problems.
#1 Sticking caliper
#2 Collapsed brake hose going to said caliper (internally collapsed hose will allow brake to grab but not allow fluid out fast enough when you let up on the pedal.
#3 Sticking brake pads, this one is a stinker, brake pads fit TOO tight to star with then rust in place. I had this happen more than once and never noticed any pulling to either side.. My fix is to remove the pads and file/grind the slide areas of the pads until they move easily in the caliper grooves.
โMay-07-2014 05:18 AM
carringb wrote:
YES, it can happen. The truck's Stability Control includes trailer sway control. If the truck detects unintended yaw, it will brake individual wheels to counteract that.
โMay-06-2014 06:25 PM
โMay-06-2014 06:20 PM
Francesca Knowles wrote:
The O.P. asked if the trailer brake controller can activate truck brakes. The correct answer is "no".
And it's a stretch to call truck stability control "trailer sway control". It will do nothing to counteract trailer sway, only attempt to solve whatever difficulty the truck is experiencing as a result of it.
Absent mechanical sway bars etc., the trailer itself will continue to sway unless its own brakes are activated to stop it, which the truck's stability system can't do.
