โOct-07-2022 05:02 PM
โOct-11-2022 07:07 AM
valhalla360 wrote:swimmer_spe wrote:valhalla360 wrote:Boon Docker wrote:
Get a cuddle bunny to keep you warm.
I prefer 2. Otherwise my backside gets cold. Unfortunately someone vetoed that option...but seriously. Leaving the door open is the simplest option.
We have a 22RR. I can't find the 22BP but I assume it's a similar situation.
The furnace is mounted under the oven and there is one heating vent pointed toward the back and one toward the front, with both coming out of the main kitchen cabinet. There is no heating duct to the bedroom.
Honestly, we rarely use the furnace as a 1500w space heater is usually plenty down to around 30F. When it is cold, if we close the bedroom door, yes, almost no heat goes to the bedroom and there isn't room to put a space heater in the bedroom.
A simple solution assuming you have shore power is to turn the air/con fan on (fan mode not cooling mode). This will circulate the the warmed air from the back up to the bedroom as the air/con is ducted with a vent in the bedroom.
One item that might help clarify answers: Why do you not want the door open?
It is the 22RR. I misread it....
I did not know I could run the fan on the AC unit. It does not have a separate panel. If that is all I need to do, then that would work for some places. It also means that for others, I'm investing in a Honda generator....
You might need to get someone to wire the thermostat to allow it. The digital thermostats combine the air/con, heat and fan functions and automatically select which fan (furnace or air/con) is run. But it shouldn't be anything complex to wire in a switch for the air/con fan. The fan by itself doesn't draw a lot of wattage, so should be no problem for the electrical system to run both air/con and furnace fans.
Alternatively, you could check if there is a heat strip option for the air/con. As mentioned, a 1500w space heater does quite well down to around 30F, so a heat strip should handle things unless you do really cold weather camping.
โOct-11-2022 07:04 AM
โOct-11-2022 06:57 AM
JaxDad wrote:
I had a similar issue and solved it with a pair of 4โ square 12 volt muffin fans intended for computer cooling. I put one at the top blowing in warm air off the ceiling and one on the floor blowing cold air out. They are nearly silent and draw very little power.
The key is they run non-stop, not just when the furnace is cycling.
โOct-11-2022 06:56 AM
โOct-11-2022 05:00 AM
โOct-11-2022 04:18 AM
โOct-10-2022 09:29 PM
swimmer_spe wrote:
- A portable buddy heater set to low. Depending on what time we go to bed, it will usually run until about 4:30 or 5:00 before the fuel runs out. Looking at your floor plan, you have room for one.
No where to put it safely without it touching something.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โOct-10-2022 05:50 PM
โOct-10-2022 05:42 PM
dedmiston wrote:
- Furnace under the stove in main living area
- No ducting to the bedroom
- Door needs to stay closed for privacy. (I assume that includes the bathroom door.)
Those are pretty hard constraints.
I camp a lot in the winter in sub-freezing temps and our furnace is ducted but it isn't great in our front bedroom. So I think I'm pretty familiar with your situation.
We leave the furnace set to somewhere between 55 and 60 to keep the main areas warm and keep the enclosed belly warm enough to prevent freezing. This doesn't keep us warm in bed though.
Our strategy is:
- Extra blankies
- Sleep as close as practical (including sometimes a dog on top of the bed)
- Get up around seven and put on sweats and move around until it's practical to go outside and start a fire.
- If we're super cold and nobody is near enough to be bothered by the sound of a gen, we'll fire up the gen after seven and run the electric fireplace to heat the place up to 70 so we can run around in cutoffs again like fools.
You just have to be creative though. There are lots of options, but you can't say no to all of them, or else you'll still be cold.
โOct-10-2022 05:37 PM
ssthrd wrote:
You have given a negative response to every suggestion given, so looks like you might have to grin and bear it. Being from Sudbury, you should be used to chilly winter temps. Lol.
If privacy is an issue, and you don't want the door open, you are done. If not, then crack the door or leave it open and get a 12v USB fan for $20 from Canadian Tire.
Maybe hunting in winter is not in your future; at least with what you have.
โOct-10-2022 08:42 AM
โOct-10-2022 08:26 AM
โOct-09-2022 06:22 PM
Pbutler97 wrote:MitchF150 wrote:
It seems strange that the bedroom does not have it's own vent?
If you ever take a tour of one of the Indiana RV factories, any of them, it would not seem strange. They look for the cheapest, fastest way to do anything. If it would take 5 extra minutes on the line to run a piece of 4" flex duct to the bedroom you're not getting it. It's good enough. And even if you did get one chances are it would be crushed, ripped, unsecured, or full of sawdust and other debris.
โOct-09-2022 10:21 AM
