Direc tv antenna
mhawk4
Today i found what i was looking for while on a trip to the land-field. After a few minutes of convincing the attendant, i was able to pull this out of the blue metal box.
I already have an extra satellite box in the attic and plenty of wire.
I am building a base out of pvc pipes unless i come across a tripod, :B just direct me where is a road construction :C
For the questions; need to know if one of you guys is using this antenna or similar and how many cables you are using with it?
Then i guess i will use the outside cable connector to get signal into TT. I imagine connection in the TT is similar to the one in the house.
OK, how do i set the signal for the reception?
I will have more question later, thanks for the help.
Luis
1997 Ford F350 7.3L DRW
2016 Keystone Hideout 31RBDS
Blue Ox sway pro, Stromberg Carlson A-frame cargo tray CC-255
Luis,Shelia,Noah,Gabriel
All about the family!!;)
22 REPLIES 22
tvman44
I have a couple just like that and they work for standard definition. I run 2 cables to the camper for the 2 receivers in the camper. You only need 1 cable for 1 receiver. If you have a activated receiver in the house just take that receiver with you camping, no extra charges that way, or activate the extra receiver for $5.00 a month (Just do not tell them it will be used in your camper or they will want more money).
Papa Bob
Husky 16K hitch, Tekonsha P3,
mhawk4
Randu wrote:
Should work fine if LMB's are good and you watch Standard definition--I've been told it will not work with HD. I have 3, 1 for house, 1 mounted out in yard for trailer use, and 1 in the trailer for traveling. Randu
Thanks for the replies. I am not worry about HD, it is camping and having a TV is a luxury.
Randu; when you are using the antenna in your trailer- how many cables you are running from the antenna and which connector in the LMB are you using?
Dave and Homer thanks for pointing in the right direction.
Homer1
Lowes, Home Depot, Target, Meijers, all handle the tri-pods.
Dave_H_M
I got my tripod at lowes. It is the universal kind for mounting antennas on roof tops.
conduit fit right down in there and the dish mount slid right on the conduit.
Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
Georgew48
I have one just like that sitting in a pile of junk ready to go to the dump. A lightning strike took out all of the LNB's so Direct TV came out and put me a new style dish on the house. They told me to just toss the old dish because it was outdated and useless. Hope yours has good LNB's and will work with you boxes. Good luck.
2015 Georgetown XL 377 TS 38 foot motorhome.
1929 Model A Ford Sport Coupe
2009 Honda TRX 420FA Red (Hers)
2009 Honda TRX 420FA White (Mine)
1999 Chaparral 2130 SS limited edition ski boat
therink
Will not work for HD and the dish in the photo is outdated. You will need a slimline 3 or 5 HD dish or similar to receive HD programming.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Crazy_Ray
I hope you have active account with DirecTV. I use about 30 feet of line.
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
