Do you tow a Jeep behind your 5th wheel?
Crodad
I've seen people do this. If you do this what advice would you give me. I am planning a long trip from South Louisiana to Billings Montana next year. I would love to bring my Jeep with me since we will be there for a month or two. I plan on driving maybe 400 miles or less per day. and taking about 2 weeks to get there.
2015 F-250 PSD 4x4 XLT
2016 Silverback 31RK
https://visitedstatesmap.com/image/ALAZARCOFLIDLAMSMTNVNMTNTXUTWYsm.jpg
19 REPLIES 19
Crodad
blindeyes wrote:
Fan of trucks and either I use my Ram or Jeep when towing my rv. If you are planning to that you might want to use a hitch. recommending this hitch https://www.jeepsareus.com/sku/82208219.html. What model of Jeep do you own as each model can only tow a specific weight at the back?
The camper is a 5th wheel.
blindeyes
sayoung
Cummins12V98 wrote:
sayoung wrote:
Chris Bryant wrote:
By the time you outfit everything for safe towing, you could rent a Jeep for a month probably cheaper
You beat me to it. To me best idea.
Also, does Louisiana require a different license to legally drive/tow that much combined GVWR ?
Doesnโ€™t matter itโ€™s based on your states laws.
You really should look where he lives. the OP is based in Louisiana so uses a La. license. Does La require an upgrade to tow that much combined gvwr ?
It's like my Tx " A " non CDL. If I didn't have it , only a C , and had a wreck or had to show to LEO while towing my rig , it's called driving without a license.
Chris_Bryant
Definitely get a braking system. The dynamics of that much weight pushing the rear of the fifth wheel could be hairy.
-- Chris Bryant
discovery4us
My jeep (now someone else's jeep) did just fine behind my truck, my FW, and my MH. In all cases I used a Brake Buddy auxiliary brake system.
I taped into the FW brake lights and installed a 4 pin plug for the jeeps lights. Also used the plug for other trailers I pulled behind the FW.
Just make sure both hitches, the FW and the one on the FW, are up to the job. On most trips to the desert I see at least one jeep tailgating a FW :). I won't get into the legality of it as that is a whole can of worms.
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Crodad
Rented a Jeep in Moab for two days, $230.00/day. All I need to do is get a wireless tail light for $100.00 and I'm set. I've already towed the Jeep to Colorado 5 times behind the truck without the 5th wheel.
I've towed my boat behind the 5th wheel a couple of times here in Louisiana. We just have a length requirement. I'll do my best to find out what I can in the other states.
Mickeyfan0805
Excellent point. If this is a one-time deal, this is likely the better way to go!
sayoung
Chris_Bryant
-- Chris Bryant
JRscooby
valhalla360 wrote:
Plus there is the hassle if you can't get a pull through site. You won't be able to back up with the jeep attached, so that means disconnecting before setting up camp and then reconnecting after pulling out. If you are traveling 2 weeks straight, that's a bit of a hassle.
I have watched a MH drop the toad, move the toad into site, MH back in, and hook up. Same work, but ready to leave early AM...
valhalla360
Nomad III
Nomad III
Check the tow ratings also...both for the truck and with the 5er manufacturer.
Good chance with a 2008 3/4 ton, you are over the limits.
Also, how much is the jeep braking system going to cost? That's well above most states limits for a trailer without brakes.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
DutchmenSport
I don't have an answer to your question directly, but have you considered a second person driving the Jeep as a "chase car" while you tow the trailer? Get a set of walkie-talkies and it could be a really fun adventure. This would eliminate any legal issues in any state you travel.
naturist
Bumpyroad wrote:
DOH
check the legality of this for all states you will be going through.
bumpy
Yup. Legal in some states, not in others. And they WILL pull you over, out-of-state vehicle or no.
