Even brake replacement
SKIPCAROL
Guess I should have included this above. Am considering replacing the Even brake with either Invisibrake from Roadmaster or the Ready Brake. Any suggestions?
Carol, Skip & Buddy the Mutt
2005 Four Winds Hurricane 32R
2008 Chevy HHR Toad
2 REPLIES 2
tropical36
ReadyBrake for me or nothing and you should never need any tech support, cuz it's just too simple.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
GrampaR123
Somehow your posts appeared in the wrong order, that may be why you're not getting responses. Two things.........have you tried changing the sensitivity settings to a lesser setting? And.....Roadmaster is very good at standing behind their products, they talked me through a problem with my braking system on the phone and were very helpful. You might give that a try?
