โFeb-03-2019 11:21 AM
โMar-20-2019 07:36 AM
BarneyS wrote:
Glad top hear that the hitch is working well for you.:) . I do have a suggestion though.
Rather than weld the brackets in place, it might be better to just spot weld a small bead in front of the brackets near the bottom and behind the brackets near the top to keep them in the correct position. Another option is to drill a small hole in those locations and put in a self tapping screw for the bracket to bear against.
The problem with welding the brackets on is that if/when you sell the trailer or trade it in, the brackets will have to stay on the trailer and the new owner may not want to use an Andersen. Also you may want to keep the hitch and put it on a new trailer.
Barney
โMar-20-2019 07:14 AM
โMar-19-2019 09:42 PM
โMar-18-2019 05:46 PM
โFeb-15-2019 04:49 PM
โFeb-07-2019 07:51 PM
โFeb-07-2019 04:00 PM
โFeb-06-2019 05:20 PM
โFeb-06-2019 04:14 PM
โFeb-06-2019 08:19 AM
โFeb-06-2019 07:07 AM
โFeb-06-2019 05:21 AM
bedpan wrote:
I have not seen a design that is screwed down? Have you seen any videos or descriptions of it? The video from Andersen on changing the friction material shows it as having a retaining clip. Based on my reading this was added sometime after the initial design. I read a few posts with people having the ball pop out when de-loading the hitch to hookup.pfidahospud wrote:
If I were to do it over again, Iโd make sure it was the brand new design of the insert that is screwed down to the base. Apparently Iโm not the only one whoโs had the mushrooming issue.
โFeb-04-2019 03:52 PM
bedpan wrote:
I just need to figure out the best source for me to order with in Canada. As per there website if you don't buy from an authorized dealer there is no support and I have no dealers in Ontario to try and order from..
Mike
โFeb-04-2019 01:08 PM
