โSep-09-2018 10:58 AM
โSep-09-2018 04:21 PM
โSep-09-2018 04:02 PM
โSep-09-2018 03:44 PM
azrving wrote:
A lot of people use talk to texting so things happen. I've corrected mistakes only to see it messed up again after I post it.
There's some reason for it and it's not fixing itself. Get the tire off the ground and see if it's loose bearings. Rotate it back and forth. It could have brake parts mangled and clunking around in there.
You can buy a whole backing plate brake assembly for $50 to $100. If the bearings are trashed hope that they didn't tear up the axle stub. That would be the worst case and complete axle assemblies are available for surprisingly low prices.
โSep-09-2018 03:03 PM
โSep-09-2018 01:50 PM
BB_TX wrote:
If you are going to be there a few days you might call a mobile RV repair service.
โSep-09-2018 12:22 PM
โSep-09-2018 12:01 PM
NMDriver2 wrote:
Did you check the break away cable? All the other wheels may not be as tightly adjusted as the one that blew so they kept turning. Check brake adjustment on all wheels.
โSep-09-2018 11:31 AM
โSep-09-2018 11:24 AM
โSep-09-2018 11:09 AM
donn0128 wrote:
Brake locked up is my first guess. Pull the hub and look. I would guess something to do with the brakes broke. If the hub was not extremely hot then its likely not a bearing issue.
โSep-09-2018 11:00 AM
