โMay-02-2022 10:06 AM
โMay-04-2022 05:12 AM
austinjenna wrote:
Its a gimmicky trailer that only a few tree huggers will buy at that price and feel good about how they are not leaving a footprint by having a green trailer.
If I am going to spend 80K on a rig it certainly is not going to be that one.
โMay-04-2022 04:32 AM
โMay-03-2022 11:21 PM
valhalla360 wrote:fj12ryder wrote:
Seems it would be better to have propane for cooking, hot water, and outdoor grill than electric. Just my thought anyway. I do wonder how long they can withstand rainy or cloudy days. Having propane would allow you to stretch the electric power farther. And personally I prefer parking in the shade, and solar pretty much won't allow you to do that. Parking in full sun in the midwest in the middle of summer would put the AC to the test. ๐
If you don't use the air/con or heat, probably indefinitely.
If you need air/con or heat, well, not so great.
โMay-03-2022 09:24 AM
โMay-03-2022 04:39 AM
โMay-03-2022 04:03 AM
โMay-03-2022 01:50 AM
โMay-02-2022 10:29 PM
time2roll wrote:Skibane wrote:Compared to the roof shaker over the bed? How bad can it be?
So you get to sleep right on top of an air conditioner that's cycling on and off all night?
โMay-02-2022 07:43 PM
โMay-02-2022 07:22 PM
โMay-02-2022 04:57 PM
โMay-02-2022 04:09 PM
way2roll wrote:
Mentioned an under the bed AC unit
and detailed about the insulation that helps keeps things cooler (or warmer).
โMay-02-2022 03:42 PM
โMay-02-2022 02:48 PM
โMay-02-2022 02:11 PM
Skibane wrote:
Perhaps I missed it, but didn't see any mention of how they heat or cool it.
14.3 KWH of battery energy is just slightly under 50K BTU - Enough to run a 12K BTU air conditioner for around 4 hours a day (assuming perfect efficiency, 100% battery discharge, and no other electrical loads being used).
I assume they would use some sort of heat pump for heating, since resistance electric heat is very energy-inefficient.
Typically, you get less sunlight in cold climates and during cold seasons - so there would often be less solar panel output available for heating. On rainy or completely overcast days, you either make do with whatever's still in the battery, or do without.
