Flat towing 2005 Chevy Tahoe
Thats_how_we_ro
Hello,
My Husband and I are total newbies and need some information on towing. We recently acquired 2004 Beaver Patriot Thunder with 505 Cat diesel engine. We were wondering if it is possible to Flat tow a 2005 Chevy Tahoe 4WD?
What if any special is needed to flat tow the Tahoe?
Any Help is Greatly appreciated.
Thanks in advance for any help
Moved to Dinghy Towing forum from Towing.
5 REPLIES 5
Thats_how_we_ro
Thank You All very much!!
All of your responses have been very helpful and greatly appreciated.
I can see joining this forum is the beginning of something Really Good ๐Ÿ™‚
Passin_Thru
Try Chevy and Duramax forums.
docj
Your Tahoe should be flat towable if the transfer case (the 2WD/4WD switching device) has a neutral position. Look in your owners manual and it should have the information for putting the transfer case into neutral. As I recall it involves pressing and holding two of the buttons at the same time. Most of the GM 4WD transfer cases have a neutral position, but not all, so you need to check yours.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
The_Texan
Yes, your Tahoe can be flat towed, without any modification to the drive train. On the left side you have the 4wd control. There is a line there that shows you which 2 buttons to hold in simultaneously for 10ยฑ seconds and then it will shift into N and the red N light will illuminate. Once the transfer case is in N, place the transmission in P and release the E brake. You are now ready to tow.
You can buy used base plates and tow bars on either eBay, craigslist, or etrailer.com, for a reasonable price.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
NC_Hauler
Do you have an owners manual with the Chevy? Should be able to find that information there, if not, you might want to post on the "Dinghy Forum"... It's a forum on this site for people who are towing a vehicle behind their rv.
Worse case, could call a Chevy dealer, ask for the service dept and they should be able to answer the question for you...
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
