Jan-22-2013 05:07 PM
May-15-2013 05:17 PM
CHD Dad wrote:
Following up on this - I have not received a response to two emails back to them. Site claims email reply within 3 hours which was the case when I got the canned response the first time. When I got more specific they have ignored me so far. I then placed two phone calls, 3 days apart (Mon and Wed). Both times the rep could not answer any of the specific questions that were brought up earlier. Both times the rep told me an engineer would be happy to call me back to explain how their sway control works vs. any other manufacturer with head tilt, angles of deflection needed between TV/TT, etc.
Still waiting on that call...
May-15-2013 05:11 PM
May-15-2013 09:52 AM
May-12-2013 11:21 AM
May-11-2013 09:09 PM
May-11-2013 07:28 PM
BenK wrote:The following chart shows how bar-tip force varies as a function of TV/TT articulation.
The amount of forces +/- is factored by the number of chain links, or more accurately how much the chain will allow the bar end to move or not move. The bar's preload will either increase or reduce...but am having problems with that, so see last sentence
I'll let you guys hypothesize the pound forces, both push and pull on
the tongue in reference to the center line
May-11-2013 04:21 PM
May-11-2013 07:02 AM
May-11-2013 06:48 AM
May-10-2013 09:59 PM
CHD Dad wrote:
If I follow your video, when the TT is not in a straight line the added tension on one side will help pull it back into line. Wouldn’t all designs do that? Second, how far out of line does the TT need to get on a typical 1000# hitch setup which seems the most common. Would the TT need to get several degrees or feet off center for physics to kick in on the bars to pull things straight? I thought I read that you got rid of the torque bolts to prevent “dog tracking” but other friction systems don’t seem to have that issue unless they are way too tight or on something like a snowy road.
Blue Ox Representative wrote:I consider this to be a very disappointing response to your specific questions.
Thank you for your interest in the Swaypro, we built caster into the trunions of the hitch head. This is what gives you the sway prevention and the friction sway control is not needed, it does not need to go off center for it to work, it is always working. This is similar to caster in a car, when going down the road the caster built into your front end keeps you straight going down the road and returns you to center when turning a corner. Blue Ox Swaypro is unique in the built in caster. I hope this answers your questions below. Please let me know if you have further questions.
May-10-2013 06:52 PM
May-10-2013 02:16 PM
CHD Dad wrote:I'd say you have a better understanding of the load-deflection characteristics of a cantilever beam than some engineers do.
Definitely not an engineer so please feel free to laugh at my comments...
I thought the whole point of any tapered bar such as what is on the Blue Ox is that tip will flex more than the base.---When a force is applied to the free end of a cantilever beam, a bending moment will be imposed on the beam.
If its the same cross section, but the material is thinner it should flex easier and faster than the thicker material towards the end of the bar going into the socket. It should be "progressively" easier to flex the bar the farther away you move from the socket as the bar tapers down in thickness.Yes, as distance from the fixed end increases, the curvature of the tapered beam will be greater and the deflection will be greater than for the non-tapered.
While the amount of force exerted to the hitch head is constant, isnt the bar designed to be progressively softer the further away from the head? My thoughts are that is progressive in nature. The tips can flex easier to help absorb any shocks or small movements and as the load against them ramps up during a turn they resist flexing the further out of line it gets.The force acting on the tip of a WD bar with a tilted trunion is close to its maximum when the TV and TT are aligned.
If not, what is the point of tapering the bar? Weight savings? You could make the entire bar smaller in cross section. It would be much cheaper than having those bars made with the taper to just saw cut mults out of plain bar stock.As mentioned earlier, with a tapered bar, you can achieve a more uniform distribution of bending stress along the length of the bar.
May-10-2013 12:51 PM
Mike Up wrote:IMO, the new Sway Pro will not come close to providing as much "sway control" as the EQ or DC do.
So Ron, am I reading correctly as you don't feel the Blue Ox is going to do much sway control or prevention as an Equalize brand hitch or Reese Dual Cam hitch will do?
May-10-2013 10:11 AM
May-10-2013 10:01 AM
