Heated Water Hose
ROADSTARJR
I'm looking at going full time and want to get a heated water hose, would like to know the best?
Joe
2000 REXHALL AERBUS 37' DIESEL
2004 Dodge 3500 DRW
2001 Sunnybrook 33 RKFS
27 REPLIES 27
PyrateSilly
We got our Pirit hose from Camping World on sale for about $50 during the summer when we did not need it. Seemed to be much cheaper then.
Abigail and Christine having fun in a 1993 Monaco Crown Royale Signature Series 40ft 300hp RV.
Trlrboy
We do the same thing as Topjimmy... heat tape. We bought a heat tape at Lowes that's 10' longer than the hose so that we could wrap one end around the connections on the trailer and then also around the spigot and pipe at the campsite. Works great.
2010 Montana 3400RL
Chevy 2500HD Duramax
PHOTOLINK
Mfar1234
PIRIT --- $100 - $200
AMAZON
:C
Mfar1234
40' 2002 Alpine Coach, 400 ISL Cummings/3000 6sd Allison
2006 Dodge Ram 4x4
Brodie - Lab Mix and Baylee - Border Collie
edatlanta
I fill up my fresh water tank and unhook the water hose when it will be below freezing and operate off of the tank. You can refill your tank even when below freezing if you allowed your host to drain after you unhooked it. Even with a heated hose, which I won't buy, you still have to worry about the water faucet you hook to. Not worth it for me.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Golden_HVAC
So you really want a $250 heated water hose?
I would rather just fill up my fresh water tank on warmer days, and dump at the same time.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
PyrateSilly
Here are some of the heated water hoses:
http://www.pirithose.com/index.php
http://heatedwaterhose.com/
http://www.rittenhouse.ca/asp/Product.asp?PG=2392&gclid=COqOwoOkgLUCFbKiPAodXhkAtA
http://www.nofreezewaterhose.com/?gclid=CPWgiZ6kgLUCFSOnPAodIz8Aww
Or you could go with the Heat Tape:
http://www.grainger.com/Grainger/ecatalog/N-1z0csvm
http://fluidxequipment.com/subcategory.cfm?id=36
http://www.lowes.com/pd_24490-72436-ADKS-500_0__
And here's how to install it:
http://www.foremost.com/mygreathome/?v=a&an=how-to-install-heat-tape
http://www.ehow.com/how_2002635_install-heat-tape.html
Hope this helps you.
kelly94942
Yup, that's what we did when we full timed, heat tape from the hardware store, wrapped with foam tube. Never froze!
Me and wonderful DH
Previous #1: 2007 Pacific Coachworks Tango 299BHS, 2007 Chevy Tahoe
Previous #2: 2010 Carriage Carri-Lite 36MAX1, 2008 Ford F-450 (full timed for two years)
Current: 2013 Dutchman Kodiak 300BHSL, 2004 Ford Excursion
topjimmy
If you are going Fulltime like I have the past 3 years you gotta have a heated hose or you can do like i do and go the cheaper route and get heat TAPE at the hardware store I think it cost me about 25 bucks and i also put foam tube wrapped around the hose also WORKS PERFECT and i have never had a frozen hose.I do not like traveling around with a full tank of fresh water it is just too much weight but that is a option to run just off the inboard tank when it gets cold
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
pianotuna
Nomad II
Nomad II
Hi,
Probably better to run on tank water. The hoses are expensive.
Regards, Don
time2roll
WoodGlue
I think there are only 2 mfgs making them. If I recall correctly, Amazon carries one brand and Camping World carries the other Brand.
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
ROADSTARJR
Thanks' But Who has the best ones?
Joe
2004 Dodge 3500 DRW
old_guy
buy only the length you need. they are very expensive
