โMar-08-2017 11:16 AM
โMar-26-2017 06:55 AM
โMar-26-2017 01:12 AM
โMar-24-2017 11:07 AM
โMar-24-2017 05:53 AM
Hannibal wrote:Cummins12V98 wrote:Hannibal wrote:
I think some of you fellers aren't familiar with the EZ-Lube axles.
https://www.youtube.com/watch?v=XT0RKDGgDm8
Good video! Notice he said "MANUAL" grease gun.
Absolutely do not use a pneumatic grease gun for wheel bearings or ball joints for that matter. And if you feel more than just a little bit of resistance, stop and figure out why. Make sure your grease is compatible with the existing grease as well.
โMar-23-2017 02:40 PM
โMar-23-2017 05:54 AM
โMar-22-2017 03:54 PM
โMar-21-2017 06:04 PM
Cummins12V98 wrote:I decided to go disk was the primary reason I pulled it apart.
Hope you replaced the seals after that much time.
โMar-21-2017 04:54 PM
โMar-21-2017 06:10 AM
time2roll wrote:
Just pulled my drums after 10 years. Maybe 30,000 to 50,000 miles.
My cheapo China bearings looked perfect.
Mobil 1 grease still had the original red color.
I will check them again in 10 more.
โMar-20-2017 08:53 PM
โMar-20-2017 08:18 PM
fj12ryder wrote:
^^^^^^Do you pull the brakes on your car/truck yearly? They generally get a lot more use than the trailer. Some inspection ideas have merit, and others not so much.
โMar-20-2017 10:40 AM
Lynnmor wrote:
I suggest just doing it right when you do the annual bearing inspection and forget the useless and troublesome grease fitting.
โMar-19-2017 03:27 PM
โMar-19-2017 01:59 PM
