โJun-17-2023 11:09 AM
โJun-19-2023 07:26 AM
StirCrazy wrote:Cummins12V98 wrote:
Don't understand your comment "that's not really making sense, pump and spin is the way you're supposed to fill the ez-lube."
It's Tie Down Engineering but now owned by Dexter. Changed out the POS spring, axles and drums with Dexter Tork Flex 3,750#. 5 or 6 year 100k warranty on the hubs, no maintenance required. I did have 3 fail so I am now annually greasing with Lucas Marine as per warranty.
Also HydraStar Hydraulic Actuator.
don't worry about it, I misunderstood what you were saying. so, I imaging that was more expensive than just buying the dexter disc break upgrade they offer for 2500Cdn for the 4 rotors , break kits and hydraulic to electric set up.
โJun-19-2023 06:59 AM
โJun-18-2023 01:26 PM
Pump and spin baby!!! GREAT way to grease the hubs. If you have drum brakes that is another story. I don't have to worry about the dreaded grease BLOWING past the rear seal as I will NEVER own another trailer with drums. Disks all the way.
On a side note, what disc brake kit did you go with?
โJun-18-2023 07:42 AM
โJun-18-2023 06:19 AM
โJun-18-2023 06:12 AM
ScottG wrote:
No big deal. Replace the zerk if it bothers you.
โJun-17-2023 03:49 PM
โJun-17-2023 03:29 PM
โJun-17-2023 12:44 PM
โJun-17-2023 11:42 AM
