Hi all,
A picked up a 2015 Ram sport and installed some BOSS air bags in the rear end. This has now made the tongue of my trailer sit quite high.
My ball mount is adjustable, however the way the ball mount was situated it was at its lowest setting. Tonight I removed the ball and bracket for it from the mount, flipped the mount over and reinstalled the bracket to the lowest setting. I'll have to see if this sits right, and possible raise it up one notch, however I have two questions.
1. Is it OK to flip the mount over like I did? The angle support is now on the bottom (angled piece), which before it was on the top. I've seem them both ways so I am assuming it doesn't matter.
2. How tight do I tighten the two nuts/bolts that hold the ball bracket to the mount itself? They have lock washers so I assume they don't have to be overly tight since the pressure is sheering on the bolt, not pulling on it length wise.
Heres a photo of the hitch after I changed it:
http://i.imgur.com/lp2fu2y.jpg
Thanks.
