โApr-16-2017 01:33 AM
โMay-02-2017 09:31 PM
โApr-22-2017 10:03 PM
โApr-22-2017 11:46 AM
MrWizard wrote:
It's not the motor or digital pad or mechanical timer
It's the magnetron circuitry that produces the micro waves
The cooking power
The mw will work on msw, it just makes less power, than when it has psw power input, warming up a cup of water or coffee takes longer, but it's also easier on the batteries, because it draws less inverter power, less amps from the battery for a longer period
โApr-22-2017 11:34 AM
โApr-22-2017 09:38 AM
โApr-22-2017 08:32 AM
โApr-19-2017 07:30 PM
โApr-17-2017 07:06 AM
โApr-16-2017 10:48 PM
โApr-16-2017 08:46 PM
โApr-16-2017 08:11 PM
cbshoestring wrote:Yes it can. And yes, heat is the enemy. It's not the only reason they're cheap, however.
. It mentions "cooling" as "open ventilated". Since it does NOT mention a continous fan/or temp controlled fan...just vented.... can it be ASSUMED there is no cooling fan
โApr-16-2017 05:49 PM
westend wrote:
Holy moley, they also have a 2000W PSW for $135. That is a real savings if these are durable. I'd assume they are similar to most of the usual brands.
โApr-16-2017 05:17 PM
GaryS1953 wrote:You will have much better luck with a standard 120v tv.
Don't yet have a TV for the camper, but thinking about a 12 volt LED unit.
โApr-16-2017 05:14 PM
