House batteries (has 2) durning storage.
cougar28
On our new 5er it has a battery disconnect switch but doesn't shut every thing off. Just had a RV carport built but to far away from ac power to plug in. So thinking maybe a solar charger to keep the batteries charged
plus the demand. Or another disconnect switch directly off the battery to totally disconnect them and maybe a small solar charger.I don't want to pull the batteries because I do check things every 3 or 4 weeks inside and out during storage just making sure there's no problems with anything. What do you do? Your thoughts?
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
12 REPLIES 12
camperdave
Dave H M wrote:
OK folks set me up with a scenario where I could hook up and hit the road with the battery disconnected? I guess it is possible to do that somehow.
Not only would you have to forget to connect the battery cable (which would only be possible if you don't have power landing gear), but you would need to have the hitch fail. Would be some long odds, I'd think.
2004 Fleetwood Tioga 29v
Sam_Spade
BUT.....why would you want to do that ?
Many systems will change a little off the tow vehicle while it is running.
The fridge won't run on propane with the battery too.
And then there is the problem with the brakes.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Dave_H_M
PNW_Steve
Opnspaces makes a good point. You need to make sure that you accommodate the breakaway brakes.
I put a 300 watt panel, Renogy Rover MPPT charge controller and 2 GC-2's on my 5er like Ajriding suggested. When stored it sits at 13.6-13.8volts float. I have been monitoring it and feel comfortable leaving it running over the Winter.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
opnspaces
Navigator II
Navigator II
Yes solar or even cheaper with a second disconnect switch at the batteries.
If you go for the second disconnect make sure you wire it so that the emergency breakaway if equipped still has power. So you wiring path should be (Positive terminal --> emergency breakaway --> cutoff switch --> trailer)
The emergency breakaway doesn't pull any power unless the pin is pulled. You want the breakaway to function even if you forget to connect the batteries before towing.
ajriding
Solar , yes.
15 watts might be enough to just tend it. I'd go 50 since it is winter an overcast and low angle of the sun.
Why not just spend a little more and have a full functioning solar system? 200 watts minimum, a good controller (MPPT or PWM) and 10-12 gauge wires.
Even if I am in a campground I will not plug in unless I want to run the AC, this is because their electrical might be so dirty it could damage my camper… Solar gives you options
PNW_Steve
wa8yxm wrote:
I like the solar charger idea. say a 100 watt panel should handle most if not all. monitor the voltage (battery) and if you see it start to drop go to 200 watts of panel but I think 100 will do it. DO not forget a good charge controller for a 100 watt panel you need a 10 amp controller minimum. I'd not go bigger than 20 amp for the controller or the loss in the box will be too great. MPPT is best.
Don't follow my example....... I was in a pinch for storage so I moved my Bluebird to a lot with no power. I knew I needed a battery maintainer but to get me by until I ordered one I connected a stray 80 watt panel directly to the batteries (3x group 31) with no charge controller.
I got away with it. I think that if it had not been November -December in the Seattle area I would have boiled three batteries... Shame on me for taking two months to get the correct maintainer....
camperdave
Solar would be a good idea. I go simple and disconnect the battery cable between my batteries (dual 6 volters) when in storage. One nut, only takes a minute on mine.
PNW_Steve
Google "solar battery tender"
It's a small solar panel and charge controller that simply floats the battery.
I would recommed that you top your batteries with DISTILLED WATER while you are preparing for storage and again at the beginning of next season.
memtb
I, also think that the solar charger is a great option. But, make certain that your charge controller has a “float” mode, as “”not” to overcharge (cook) your batteries. I went really cheap on my hydraulic dump trailer ( no electrical power where I keep it parked), a very small panel, and an “el-cheapo” controller. Ruined a battery in less than two years. memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Sam_Spade
How far away from the nearest outlet IS it ?
I suggest that a long extension cord and a small "Battery Tender", or equivalent, maintenance charger would be best. Probably would keep them charged OK if connected only a day or two a month.
wa8yxm
