โJan-05-2016 08:08 AM
โJan-06-2016 12:03 PM
eichacsj wrote:
You all misunderstood the use of the wire. It is only used to hold the chains long enough to roll one revolution of the tire to wrap the chain around the tire. You then remove the wire and link the chains as normal. Why this method instead of draping them over the tire? Because they get on so much tighter, so tight that I don't use tighteners unless on the highway.
โJan-06-2016 11:57 AM
โJan-06-2016 08:21 AM
Dave H M wrote:CavemanCharlie wrote:
Bailing wire ??? I didn't know you could get that stuff anymore. Haven't tied bails with wire since the 30's. It was multi strand wire and it was very hard to work with.
Go to a big box store like Lowes and get a roll of the wire that will be next the rebar. It closely resembles bailing wire. I would not be without in the barn/shop.
โJan-06-2016 08:15 AM
โJan-06-2016 07:26 AM
โJan-06-2016 07:05 AM
smkettner wrote:
No bailing wire for me.
Lay down a board parallel to the axle.
Lay down the chain and drive onto the board.
Connect the inside, connect the outside.
Install tensioner and off I go.
โJan-06-2016 04:58 AM
โJan-06-2016 02:16 AM
WyoTraveler wrote:
The new cable chains go on much easier. They have a break and connector in the middle on one side also. Slip the chain around the wheel on the ground and close that connector. Bring it up over the tire snap remaining connectors. No need to back over them any more like link chains. Approved in most states for commercial trucks and busses. I have a set for my MH. Also lighter in weight. They have some videos on the internet on installation. I do use rubber tighteners.
The chain installers at the chain up places use jacks for old link chains because it is much faster and they don't want to enter and drive your vehicle and don't trust drivers for backing over and stopping etc.
โJan-05-2016 11:18 PM
โJan-05-2016 09:37 PM
โJan-05-2016 09:15 PM
โJan-05-2016 08:57 PM
โJan-05-2016 05:49 PM
โJan-05-2016 02:15 PM
