How to check electricity at a campground
GizmosMom
I just read a campground review where the RV-ers checked the electricity at 3-4 sites before they found one that was good.
We have been RV-ing for many years. We don't check but I think it is about time for us to do so. I did a search here on the forum but I could not find any posts relating to checking the electricity. I am not using the correct terminology, I am sure.
Is this a special meter or something else? I would like your recommendations for one, if possible.
Thanks!
Marilyn w/ Joe, 2016 Class C Sunseeker 2430 SF, often pulling a Ranger bass boat. Traveling with Trigger
Smudge & Gizmo are waiting at the Rainbow Bridge
19 REPLIES 19
GizmosMom
Thanks, everyone. This information will help us so much.
Safe travels...
bob213
I use the same setup a IAMICHABOD has in the above "This recent Thread". I test before I plug in my P.I. EMS wherever I'm at.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
IAMICHABOD
Try This recent Thread
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Lynnmor
At a bare minimum, get a digital voltmeter that plugs into an outlet and keep it plugged in where you can easily see it. Do not run a air conditioner below 104 volts. Voltage can vary throughout the day. Others will be alone suggesting various devices that are helpful.
Sam_Spade
Do a Google search for "electrical tester".
This is one of the things that came up for me:
http://www.globalindustrial.com/p/tools/test-measurement/Metrs-HVAC-R/gardner-bender-gfci-outlet-tester-120-vac?infoParam.campaignId=T9F&gclid=CjwKCAjwk4vMBRAgEiwA4ftLs6XaP9vf4CEG5S0ZJcFPIg4nyPMhResJOH6A-tW2s06tYAslpV-IIxoC0bkQAvD_BwE
It is a simple quick test for "major" faults only and you would need an adapter to test 30 amp outlets. It will NOT completely test a 50 amp outlet.
More complete tests are included with a medium to high end "surge protector", often prices around $100 or more.
It depends on what your budget is and how thorough you wish to be.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
