Aug-11-2013 04:52 PM
Aug-12-2013 08:20 AM
Aug-11-2013 06:23 PM
Aug-11-2013 06:14 PM
Aug-11-2013 05:42 PM
Aug-11-2013 05:41 PM
Sundance07 wrote:
Yes, you can just change the stock cover if you choose to.
Take the screw out of the handcrank from the inside so that you can remove the inside frame and screen. Then disconnect the linkage from the vent.
Then get on the roof and open the vent fully by hand. You can then slide it sideways out of the C channel that holds it. The channel may have a little bend in it at the ends to prevent it from moving it sideways. Just bend it open enough to slide the cover out. There may also be a screw in the channel that does the same thing. Just remove it to slide the cover out.
Slide new cover on, hook up linkage, reinstall screen and crank and you're done!
Aug-11-2013 05:39 PM
PapPappy wrote:'
Depending on what is wrong with the old vents, you may want to just get a cover for the vents.
MaxAir Vent Cover Will go over your existing vents, and you can leave them open....it works with the fans too.
Aug-11-2013 05:11 PM
Aug-11-2013 05:00 PM
Aug-11-2013 04:59 PM
