โAug-14-2023 10:54 AM
โAug-19-2023 03:59 AM
โAug-18-2023 07:59 AM
โAug-18-2023 07:37 AM
valhalla360 wrote:
Are wheel balancing machines able to conduct internet searches for tire size...if they are lug centric?
โAug-18-2023 07:24 AM
fj12ryder wrote:NamMedevac 70 wrote:So you don't balance your car/truck tires either?
In 17 years I have placed new Goodyear and Maxxis tires on my TT by shops and myself and no wheel or tire balancing was needed. Never any tire wear or problems during those many years. I do not know so called lug centric balancing. My simple RV life has been great fun and rewarding with no complicated equipment, toys, etc. Plain is good and comfortable. Object focus was camping and not Others have gone dus
Cheers to the comfortable good life and 4 Rs
โAug-18-2023 06:08 AM
โAug-18-2023 06:07 AM
bucky wrote:Yeah, that was an exaggeration, but it was a lot, measured ins square inches, probably 4X6. I took 'em all off before I put them on the trailer. Just couldn't believe it was right. LOL
5 POUNDS of weight on each wheel? Let's try 5 ounces!
โAug-18-2023 05:33 AM
โAug-18-2023 04:01 AM
โAug-17-2023 06:49 PM
โAug-17-2023 04:15 PM
โAug-17-2023 04:04 PM
CapriRacer wrote:I can see the idea, but my issue isn't with the tires/wheels, it's with the drums that the tires/wheels mount to. How precisely are they positioned in relation to the center ring? Nothing about those drums says "precision". ๐fj12ryder wrote:
Okay, I watched, most, of the video on balancing tires, and no where does he mention that many, perhaps most, trailer wheels are lug-centric, and almost no one will balance lug-centric wheels. I asked a guy at the tire dealer why they don't balance lug-centric wheels and he said they do. But they balance off the center which he said works fine. But if the wheel is balanced hub-centric, but mounts lug-centric, how is that fine? He just kept saying it's not a problem.
In theory, the wheels are machined using the center hole as center - and that includes the lug holes. So using the center hole is nearly the same as using the lugs for lug centric wheels.
Besides, there is a tolerance for balancing - which is why they have wheel weights in increments. The difference in balancing using incremental wheel weights is imperceptible to the user. And since trailers aren't designed to be ridden in, close enough is good enough!
โAug-17-2023 04:02 PM
โAug-17-2023 11:13 AM
โAug-17-2023 09:31 AM
โAug-17-2023 06:58 AM
