I would first confirm power to the pump and the ground is good. Maney times you will have a relay click, but the contacts may be carboned up and no power goes through it. Second, will holding the switch, amy need a second person, tap on the motor of the pump with a small hammer, if it starts to run, bad motor.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
