I have a Wen 2000 watt generator. ( bought it to find out, it won't run my a/c by about.2 amps).
It does not have a 30 amp receptacle, but is parallel ready.
They don't seem to sell any other version of the 2000 watt, all are parallel ready, with no bigger receptacle.
I'm guessing it may be a 20 amp rated receptacle, and paralleling would get me 20 amps, instead of 13?
If I hook two "parallel ready" generators together, and neither has a 30 amp receptacle, what does my paralleling accomplish?
Is there an adapter, where you can use two separate power sources, and add the amperage?
Like plugging in to two generators, or two separate 15 amp circuits on a S&B, and getting 120 volts at 30 amp.
I'm surprised, I've been reading this forum regularly for over 4 years, and don't remember this question being discussed.
That alone tells me, it may be a NO, don't ever try that.
Thanks for the help.
Hopefully it saves someone else from posting.
TIA again.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
