Is replacing Jensen Antennae with King Jack an upgrade
seaeagle2
This is a different spin on the antennae debate. I have a travel trailer with the Jensen omni directional antennae. In looking at the install instructions for the Wingard and the King, I could install the King in the existing location in my TT, if I put a hinged access door on the cabinet that holds the entertainment center. The Wingard would be a major install job. I understand the Wingard is a better antennae, but would the King Jack be a enough of an improvement to justify doing it ?
2014 F 250 Gasser
2019 Outdoors RV 21RD
"one life, don't blow it", Kona Brewing
"If people concentrated on the really important things in life there'd be a shortage of fishing poles" Doug Larson
6 REPLIES 6
wa8yxm
The Jack comes in two (or 3) flavors. Directional, Omni and Winegard replacement.
A directional antenna is a serious upgrade to the Omni, No moni can outperform a directional antenna.
The Winegard Sensar IV is the best.. Add the Sensar Pro indoor module and it gets better.
NERoadRunner
I did exactly that on our camper, the Jensen antennas are junk. I installed a King Jack rotatable. It helped considerably but our friends with a crank up antenna seem to get a channel or two more than we do when camping at the same campsite.
MFL
Nomad II
Nomad II
Yes, it will be a big improvement.
Jerry
n7bsn
I haven't compared the Jensen vrs the Jack. I have compared the Jensen vrs a random length chunk of wire, and the wire worked better.
The Jensen is a piece of junk.
By all accounts the Jack is almost as good as the Winegard "Bat-wing" with the "wing-man" add on. I can't picture the Jack not out performing the Jensen.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
seaeagle2
I probably didn't state it very well, I could install the King Jack in a way in the existing location so I could rotate it.
2014 F 250 Gasser
SoundGuy
Both the Winegard Sensar and King Jack TV antennas need to be rotated for maximum performance ... if you're not going to do that then there's little point to the exercise.
2012 Silverado 1500 Crew Cab
