Kitchen Smoke Detectors
rhagfo
Well just recently installed a new โ€œKitchen Ratedโ€ smoke detector (about 2 months ago), it is working as claimed. It is designed to have fewer false alarms, and is doing exactly that.
About the only thing that will set it off is cooking bacon real crisp without the range hood fan on.
If you have lots of false alarms you might think about one.
16 REPLIES 16
Harvey51
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Me, too. I dread reading a certain Dodge forum because it demands a Captcha and it isnโ€™t clear what it wants. Glad there arenโ€™t any Captchas in this forum at least via the Good Sam portal.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
CavemanCharlie
I hated the smoke detector in my 20 foot TT. The smallest amount of smoke would cooking would set it off. For sure Toast was a major culprit. Last year I found a newer one that was suppose to be less sensitive. It seemed to work and be what I needed. The weather has been bad this spring and I have only been camping once ( it sucks) . The other day while walking by the camper I heard the smoke detector going off. (There was obviously no smoke) I haven't had a chance to check it out yet, I just pulled the battery.
It was over 95f degrees in the camper that was setting in the metal shed that day.( Maybe over 100) Do these things go off when they get to hot ??????
FunnyCamper
Ours was near the stove and even with the fan hoods rolling on high the darn thing goes off even without smoke or some sense of true smoke/fire danger.
Took battery out. Installed a new one just behind the wall in the hallway leading to bedroom. Done deal. No more cooking troubles at all.
This is a very short span, we did not compromise safety for this short move on a new on installed.
What a true PIA when wanting to use your stove top for real cooking. Drove us nuts til we fixed the problem fine.
myredracer
westend wrote:
myredracer wrote:
Never heard of a "kitchen-rated" smoke detector. I assume it's UL or NFPA approved/listed? Have a link to tech. info? What makes it different? Nothing comes up on a google search that I can find.
Universal Security Instruments smoke and fire alarms.
Thx. for the link. The info. in that link refers to "rate of rise" which is normally related to heat/thermal detectors which are either rate of rise or fixed temperature types. A rate of rise type is triggered by temp. quickly rising above a set rate. I wonder if the kitchen-rated detector is simply a combination of standard heat and smoke detector technology and there's nothing new or unique about the smoke detection part? It does make a reference to a UL standard. Reason I'm curious is I used to design FA systems.
I also have to wonder what the regulations/code say about when and where you can use one? I wouldn't think you could just re & Re your old standard smoke alarm with a kitchen-rated one?
beemerphile1
I bought this one earlier this year. First one was bad out of the box, the replacement seems fine. It is recommended for kitchens.
From the First Alert description:
"The photoelectric sensor detects smoke produced by smoldering fires and minimizes false alarms from cooking smoke or shower steam."
https://www.amazon.com/gp/product/B000MXJ498/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I also changed the location about six feet further from the stove.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
rhagfo
Thanks for the link.
westend
'03 F-250 4x4 CC
myredracer
RollandB
Good info, thanks!
2013 Yukon
2021 Coachmen Spirit 1943RB
wa8yxm
I can not take credit for this
But some folks seem to think a top seller would be a Smoke Alarm that goes silent if you holler I'M JUST COOKING!!!
rhagfo
LadyRVer wrote:
Thanks for the suggestion. I have one which tells me when my toast is done..every morning.
Ours is a Universal brand bought a Fred Meyer, but you can get Kidde brand at HD, both labeled for Kitchen use.
Fulltimers
Mine has a temporary sensitivity setting. If it goes off I hold the test button and it backs off on the sensitivity for a period of time, then goes back to normal sensitivity.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
BB_TX
:B:B
Lwiddis
Four slices of crisp bacon, please.
