leaf springs?????
hxcburrito
im not sure if this is the right section for this question, but the mod section seemed to be all RV questions
my springs on my 1500 ram appear to be shot. my trailer is 5000 or so dry. would I be better off getting some springs for a 2500 or get a set of helper springs? I prefer to keep the money to a minimum in hopes that this is the last year I have this truck
2009 dodge trx4
2011 skyline nomad 268
Wife & 4 daughters
2005 dodge 1500 slt - 4.7l... gone and I'm glad
19 REPLIES 19
WrongWayRandall
Springs take care of the bounce/recovery from bumps in the road while springs carry the weight, so if it's bouncing long after you hit a bump or pothole it's a shock issue...
- Randy
1975 Westfalia Campmobile "Backroads Wanderer"
2014 Rockwood A122 hard side popup
goducks10
104,000 on original shocks, no wonder it's bouncing. The rears are easy to take off. Take one off and push on it. If it pushes real easy then it's shot. I bet you can work it like an accordion. Impossible to do with quality gas shocks.
jerem0621
I just changed the junky expensive air ride suspension on my Town Care to A Monroe coil spring conversion kit. This included the progressive coil springs and new shocks.
When I took the old shocks off my car I could not believe how worn out they were. When my Town Car would hit a bump the car would bounce all over the road. I could fully collapse the old shock by hand once I got it out and it took forever to rebound.... And that was just laying on the ground.
Seriously improved the ride with the new springs and shocks.
I'd go to autozone and get you some shocks and spend a few minutes putting them on. You may be suprised at the difference it makes.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
hxcburrito
Miles are 104, 500 and I'm gonna guess original shocks. Last year was the most I've towed my trailer. I found some shocks for towing. Sounds like I should try that first. A guy at work keeps telling me my leafs and bad and that's why its so bouncy driving down the road, even while not hauling.the truck does seem like is sits at factory hieght still though. Maybe a picture would help?
2009 dodge trx4
Wife & 4 daughters
dodge_guy
I would go with shocks first, then airbags or helper springs.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
bguy
#1 shocks (mileage?)
#2 more or less links on your hitch chains.
Other than above have you recently begun carrying more gear in the truck or the trailer?
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
BarneyS
Sounds like shocks to me if you have the WD hitch set up right.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
hxcburrito
I feel they are shot because recently, the back end is very bouncing. I've been towing with it for 3 yrs. not very often, or very far. I got the truck from a dealership 4 yrs ago. im not sure what the truck was used for by the previous owner. the truck does still sit with the back end higher then the front. I do have a WD hitch, and it does level the truck out really good. so, im pretty much assuming with how bumping of a ride it has become, that it is my springs and shocks
2009 dodge trx4
Wife & 4 daughters
goducks10
Unless you've been hauling a 1,000lbs for the last 9 years I highly doubt your springs are shot. A 2005 truck should have springs that last for years. My guess is your WD is not right.
Old-Biscuit
X whatever on the spring shop
ChooChooMan74
#1 Spring Shop
#2 Air Bag Helpers
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
Ron_Gratz
Why do you think the springs are shot?
Even if you are using a weight distribution hitch, your truck probably will have noticeable rear-end sag when the trailer is attached.
With a properly sized and properly adjusted WDH, it is not uncommon for the rear end to be 1.5-2" lower with TT attached and WD activated versus unhitched -- even when the springs are new.
Ron
Ron3rd
X11 on the spring shop route.
Equilizer Hitch
Honda EU2000
rockhillmanor
mkirsch wrote:
Cheapest option is to take the truck to a spring shop. Have them reset the curve in the springs, and add a leaf.
X10
Go to a frame/spring shop. They actually have formula specs for figuring out what is just the best route to go for your truck.
Not a truck but I took my MH to one of those shops. Best thing I ever did. After listening to all the wrong******how to fix my problem from local repair shops.
I went with new leaf springs and they added one leaf. BEST thing I have ever did to a vehicle.
