Lippert slide out slicker set - how to properly install?
Winged_One
Bought a set of Lippert slide out slicker sets at the Coachmen rally.
Tried to use one on each of the 2 rear slides. The slide out just pushed them in, did not slide on top of the slicker.
Both set up on carpet.
Cannot be there in person to ensure they stay put, as the rear of the coach is inaccessable when closed.
Any advice on how to use these, so they will stay?
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
4 REPLIES 4
FlatBroke
I made my own with some plexi glass. I installed tread grip tape to help grab the carpet. Don't need them on this current trailer but I thought of making one out of one of those plastic mats you put under a desk chair. Those suckers should grab.
Hitch Hiker
"08" 29.5 FKTG LS
tvman44
No problem with ours. ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
Winged_One
missourijan wrote:
I have a set of these and you start bringing the slide in, stop, go back and push the slicker under the slide a bit then bring the slide in the rest of the way. The roller kind of pushes the slicker along the carpet unless you do this.
Thank you!
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
missourijan
