Lost 12V to Propane sensor alarm
Chandler1
I had another propane solenoid go out and this time it took out the 12V to the propane alarm. The propane alarm powered the solenoid. I decided to eliminate the propane solenoid and just use alarm. I can't figure out where the 12V comes from because all of my DC fuses are good. I ended up taping into a light switch above the propane alarm to get it back going but would like to discover the power scheme they use and if there is another location for that fuse. 1998 Fleetwood Jamboree GT 31' Class C.
6 REPLIES 6
Chandler1
I replaced it 2 years ago.
ksg5000
What model propane detector? Given the age of the rig it's possible you have one of the CCI detectors (mfg out of business now). If it is a CCI detector then given the age you should consider buying a new propane detector and solenoid - hot-wiring it ain't going to make it more reliable. Just my 02.
Kevin
Old-Biscuit
Chandler1 wrote:
House battery or engine battery?
House...it is part of the 'coach'
Chandler1
sch911
I had one RV that had an in-line fuse holder powering the LP Detector. Just an FYI...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
Old-Biscuit
LP Detectors are typically wired directly to battery ---constant battery power so alarm is functional 24/7
