Mount brake controller with velcro?
Raife
So I purchased a Tekonsha P3 electronic brake controller for my 2015 Dodge Durango. Rather than drilling into the dash, I was considering mounting it with industrial velcro. I plan on mounting it in front of my right knee.
Has anyone done this? Did it stay (I live in central Texas).
Thank you.
12 REPLIES 12
Raife
I looked again and think I will use the pocket mount of the P3. In addition to removing the unit easily, I can remove the "pocket" portion as well for the gaps in towing. Then I just have the small little bracket still there.
Sjm9911
Depends on the velcro, the industrial stuff is pretty good. But i wouldn't want to be grabbing for the break controller and have it fall off in my hand. So i used the screws last time I did it. When I sold the truck no one noticed.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
wnjj
As I mentioned on your other thread, Iโ€™ve used the 3M dual lock fasteners that came with my (Tekonsha) brake controller for years. It works great and took years before the adhesive failed and seconds to replace it when it did.
Itโ€™s 2 strips of something like this: https://www.amazon.com/Dual-Reclosable-Fastener-SJ3560-Clear/dp/B07QNMBB28/ref=sr_1_5?dchild=1&keywo...
Like was mentioned, take the controller out when not in use to further the life. Alternatively you could just keep the rest of the roll under the seat and just replace it as needed.
I use the dual lock in one vehicle and the bracket in another since both never tow at the same time.
Labman7
I did that, worked for 2 years before it fell off on a hot day while parked.
pitch
I have a small inverter velcroed to the floor. It stays there pretty much permanently. When I have to take it out it is a bear to move. Velcro is amazing.
If your goal is not to mar your interior, I think the adhesive would probably mess your knee panel up horribly..
JRscooby
eHoefler wrote:
It would vibrate and wiggle around causing it to give eratic signals to the brakes and possibly not work as intended when needed.
What? Do you think there would be that much movement? The controller is pretty light, don't take much to hold it.
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
dodge_guy
All you need is 2 small holes to mount it. I wouldn't even worry about it.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JRscooby
The Velcro will hold pretty well. Heat will weaken the hold of adhesive. How much time will you park with trailer hooked up? If you are like most, "1 weekend a month, plus 2 weeks a year" you might be better to pull controller of Velcro, unplug, and put it in glove box when not in use. Most of the time the glue would only need to hold half the weight of Velcro.
And if you never plan to unhook Velcro, why use it? The right double stick tape?
MFL
Nomad II
Nomad II
I just don't see the velcro adhesive holding in a vehicle parked in the hot sun. I'd just use the screws. The 2 small holes drilled will hardly be noticeable on the lower part of dash. You do know that the actual hole will be much smaller than the screw appears...right? ๐Ÿ™‚
Jerry
carringb
Using the standard bracket, I don't think it would be secure enough. The Prodigy P2 has an optional pocket mount, and this does work well with velcro. The P2 brakes the same, but doesn't have as fancy of a screen. I don't know if the P3 will fit the P2 pocket mount.
2014 ORV really big trailer
2015 Ford Focus ST
rexlion
Hard to imagine velcro holding up to the weight. The hook & loop may stay fastened, but I'd expect the adhesive to give out on the other side of the tape.
I drilled my holes into the ashtray door and mounted my P3 there. I figured I could probably buy a replacement ashtray if I wanted to someday sell the truck. Just a thought.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
